.NET
Valued Contributor
NKCAUTOCAD01
Message 1 of 3 (155 Views)
About an object event, I want you to tell me.
155 Views, 2 Replies
01-15-2013 11:14 PM
Using AutoCAD.NETAPI, I had same advise the method that handled object event
(Objec tAppended) in our discussion group
and came to be able to pick up an event when I carried out paste1 in the following logics.
Public Sub Paste1() 'object addition event
  Dim tdoc As Document = Application.DocumentManager.MdiActiveDocument Dim tdb As
  Database = tdoc.Database AddHandler tdb.ObjectAppended, AddressOf ObjectAdd
End Sub
 However, trigger of the double of the number of element that I stuck by
this event occurs when I stick the element which I took in _copybase in _pasteclip.
In addition, ObjectId, OwnerId of the element becomes inherent each, too and which is
a real element or, in each trigger, cannot distinguish it.I analyze only a stuck element
I want to handle it, would you advise a method to distinguish?
Thanking you in advance.
Moderator
Alexander.Rivilis
Message 2 of 3 (143 Views)
Re: About an object event, I want you to tell me.
01-16-2013 02:22 AM in reply to: NKCAUTOCAD01
Command _PASTECLIP create temporary block definition with entities copied  _COPYBASE command. After specifying insertion point, block will be erased and entities added to current space (Model or Paper). You can check Entity.BlockId equal Database.CurrentSpaceId or no.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
NKCAUTOCAD01
Message 3 of 3 (123 Views)
01-16-2013 05:12 PM in reply to: Alexander.Rivilis
Dear Mr. Alexander.Rivilis
Thank you for the Great advice.
It was saved very much.Yours sincerely,
NKCAUTOCAD01 (M.Tsukamoto)...
