.NET
Petter
Message 1 of 6 (1,150 Views)
AXDBLib (ObjectDBX Common 16.0 Type Library) gets corrupted by Inventor
1150 Views, 5 Replies
01-11-2006 08:30 AM
I have Autodesk Inventor Professional witch include Mechanical Desktop and AutoCAD, Vault 4.0 and Visual Studio .NET 2003 where I use Visual Basic.
When I start or update Inventor my Autocad reference library AXDBLib (ObjectDBX Common 16.0 Type Library) gets corrupted. If I reinstall Mechanical Desktop the library gets corrected and I can continue to code against Autocad. But I have got quite tired of it by now. Can someone please explain.
Petter.
*Tony Tanzillo
Message 2 of 6 (1,150 Views)
Re: AXDBLib (ObjectDBX Common 16.0 Type Library) gets corrupted by Inventor
01-11-2006 09:30 AM in reply to: Petter
Can you be more specific than 'gets corrupted' ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5056167@discussion.autodesk.com...
Petter.
Petter
Message 3 of 6 (1,150 Views)
01-12-2006 05:28 AM in reply to: Petter
I have a project in .Net and under references I have attached the library AXDBLib. If I start Inventor and then open the .NET project the AXDBLib has got a yellow mark on it in the solution explorer. And under property AXDBLib has no connections. Now I can remove AXDBLib and add the reference again. But now it won’t work. The line
Imports Autodesk.AutoCAD.Interop.Common
is not valid anymore, and all commands under this library fails. The library now refers to another path (see below).
When working:
Identity: {C295FFF9-3572-4ED2-9E42-0DAADB8D93EE}\1.0\0\primary
Path: C:\WINDOWS\assembly\GAC\Autodesk.AutoCAD.Interop.Common\16.2.54.0__eed84259d7cbf30b\Autodesk.AutoCAD.Interop.Common.dll
When not working:
Identity: {C295FFF9-3572-4ED2-9E42-0DAADB8D93EE}\1.0\0\tlbimp
Path: C:\VB .NET 2003\Autodesk\Autocad\PmCadCommands\pmCadCommandsDebug\obj\Interop.AXDBLib.dll
*Tony Tanzillo
Message 4 of 6 (1,150 Views)
01-12-2006 08:48 AM in reply to: Petter
In Solution Explorer, select AxDBLib.
In the properties window, what is the CopyLocal property set to?
wrote in message news:5057074@discussion.autodesk.com...
below).
When working:
When not working:
Petter
Message 5 of 6 (1,150 Views)
01-13-2006 01:49 AM in reply to: Petter
CopyLocal is set to true.
Petter
Message 6 of 6 (1,150 Views)
01-13-2006 05:01 AM in reply to: Petter
Correction.
When woring CopyLocal was set to False.
When failure CopyLocal has changed to True.
You are not logged in.
Announcements
Need installation help?
Ask the Community
