.NET
AESWAPBLOCK Replication
2 REPLIES 2
Elad51
343 Views, 2 Replies
I am looking to replicate a process in the command AESWAPBLOCK. If a user were manually performing this process, they would do the following:
  • Open drawing to update
  • Type AESWAPBLOCK
  • Select "Library Swap"
  • Click "OK"
  • Change the path
  • Check "Include subfolders"
  • Click "Active Drawing"
Would you explain the process needed to do this through code?  I have very limited experience with programming for AutoCAD, so detail would be appreciated.
Thank you for your time.
Tags (3)
2 REPLIES 2
hgasty1001
in reply to: Elad51
As "AESWAPBLOCK" it's not an AutoCAD command (a vertical?), it's better you explain the functionality of that command.
Gaston Nunez
Elad51
in reply to: hgasty1001
Thank you for letting me know that.  The users have AutoCAD Electrical on our computer.  I guess it is a command specific to AutoCAD electrical.
The users have built circuits made up of wires (lines, I think) and blocks.  The blocks they have created are in seperate files.  If they change a block in one file, they want that block updated in every other file it is used in.  They can use that AESWAPBLOCK command to do so, however, it takes a really long time, and they would like the process automated.
”Boost
