.NET
3D Solid Bounding box
3 REPLIES 3
scarta
987 Views, 3 Replies
I would to know if there is a way with vb.net for extract the bounding box coordinates of a 3d solid
3 REPLIES 3
Alfred.NESWADBA
in reply to: scarta
doesn't that work four you?
Public Overridable ReadOnly Property GeometricExtents As Autodesk.AutoCAD.DatabaseServices.Extents3d
     Member von Autodesk.AutoCAD.DatabaseServices.Entity
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
sanpo
in reply to: Alfred.NESWADBA
Hi!
Do you have a similar solution for VBA or AutoLisp?
norman.yuan
in reply to: scarta
It is in AutoCAD COM API from the beginning for VBA: Acad3DSolid.GetBoundingBox().
”Boost
