• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    *TedSch
    2005 and 2006 on same system
    44 Views, 8 Replies
    06-13-2005 08:33 AM
    I installed 2006 on my system but support 2005 users. I built a VB.NET app
    that opens some drawings and reads xrecord information. The solution has
    no 2006 references and works perfectly on my system in 2005 and any system
    that
    has both 2005 and 2006 installed. But it gives flakey results on the
    average
    user's system that has not been touched by 2006.
    I de-installed ACAD 2006 and recompiled without improvement. This sounds
    like the vba problem where the 2004 type libraries were replaced with 2005
    and you had to be extremely careful manually swap the libraries with batch
    file
    when you were working on an update for a 2004 system.
    Does any one have a thought about what might be going on here so I can
    develop for both 2005 and 2006 on the same computer?
    Thanks, Ted
    Please use plain text.
    *Laurence Skoropinski
    Re: 2005 and 2006 on same system
    06-13-2005 09:17 AM in reply to: *TedSch
    look for Build for multiple Autocad versions, dated 18-5-2005, CArps
    solution worked a treat.
    Laurence
    "TedSch" wrote in message
    news:4873151@discussion.autodesk.com...
    that
    average
    file
    Thanks, Ted
    *Albert Szilvasy
    06-13-2005 09:28 AM in reply to: *TedSch
    What happens when it acts "flakey"? Can you describe the problem that you
    are seeing?
    Albert
    that
    average
    file
    Thanks, Ted
    *TedSch
    06-13-2005 12:45 PM in reply to: *TedSch
    Albert,
    I am showing a form with a listview grid which I am populating with
    file name, path and information from a xrecord. Half of the drawings
    I am trying to open in 2005 are throwing an error on a user's system
    but open consistently when I run 2005 but also has a version of 2006
    installed. I catch the error and note the file as "skipped".
    - Ted
    "Albert Szilvasy" wrote in message
    news:4873243@discussion.autodesk.com...
    are seeing?
    Albert
    that
    average
    file
    Thanks, Ted
    *TedSch
    06-13-2005 01:35 PM in reply to: *TedSch
    Laurence,
    Thanks. I looked but missed it. Shouldn't we be getting a proactive
    ADN newsletter about this and a switch tool that lets us toggle between
    the 2 environments made by the folks that created the problem.
    - Ted
    "Laurence Skoropinski" wrote in message
    news:4873208@discussion.autodesk.com...
    Laurence
    that
    average
    file
    Thanks, Ted
    *Albert Szilvasy
    06-13-2005 10:30 PM in reply to: *TedSch
    What is the error that you are getting?
    Albert
    news:4873530@discussion.autodesk.com...
    Albert,
    - Ted
    are seeing?
    Albert
    that
    average
    file
    Thanks, Ted
    *TedSch
    06-14-2005 06:13 AM in reply to: *TedSch
    By de-installing everything autocad on my pc and adding back 2005,
    I was able to reproduce the error on the same machine where my VS
    is located - tedious.
    But the good news is that I found the code errored on db.ReadDwgFile
    statement. I left off the arguments when I created the db object.
    'db = New Database 'old and error prone
    db = New Database(False, True) 'works - not sure why the settings are:
    false, true
    Try
    db.ReadDwgFile(DwgInfoSet.DwgFullName, IO.FileShare.Read, False, Nothing)
    Because 2006 was on my system, the (false, true) arguments
    weren't necessary - apparently. But what's confusing, on a
    2005 only system, only 50% of the drawings produced the error.
    It would be wonderful if you could explain the reason for these settings
    and why the error seems to affect only certain drawings
    Thanks, Ted
    WD Partners
    news:4873900@discussion.autodesk.com...
    Albert
    Albert,
    - Ted
    are seeing?
    Albert
    that
    average
    file
    Thanks, Ted
    *Albert Szilvasy
    06-14-2005 10:30 AM in reply to: *TedSch
    Calling the default constructor of Database (i.e. the one without arguments)
    is the same as calling Database(true, true). You can't call ReadDwgFile on a
    Database that already has the default elements (i.e. the first parameter is
    true).
    It is indeed quite interesting that only half of your drawings produced a
    problem. Nevertheless, what you are doing now (i.e. passing false to the
    first argument) is the right thing to do if you want to call ReadDwgFile on
    the Database.
    Albert
    news:4874064@discussion.autodesk.com...
    false, true
    Try
    Thanks, Ted
    WD Partners
    Albert
    Albert,
    - Ted
    are seeing?
    Albert
    that
    average
    file
    Thanks, Ted
    *TedSch
    06-14-2005 12:53 PM in reply to: *TedSch
    Thanks!
    news:4874514@discussion.autodesk.com...
    true).
    the Database.
    Albert
    false, true
    Try
    Thanks, Ted
    WD Partners
    Albert
    Albert,
    - Ted
    are seeing?
    Albert
    that
    average
    file
    Thanks, Ted
