.NET
2 different DLL's with same command name.
2 REPLIES 2
Ertqwa
423 Views, 2 Replies
Hello Forum,
if I load 2 different .NET dll into AutoCAD, and both have a command with the same name, which one will AutoCAD use?
Thank you.
2 REPLIES 2
Alexander.Rivilis
in reply to: Ertqwa
@Ertqwa wrote:
Hello Forum,
Thank you.
AutoCAD will use command defined in last loaded dll. You can check that fact yourself. 😉
Facebook | Twitter | LinkedIn
Expert Elite Member
Ertqwa
in reply to: Alexander.Rivilis
Great, thanks! Makes sense.
”Boost
