Area :: Header
Join us at EUE2014, June 5-6, Utrecht-NL
Register Now
Discussion Groups
Modeling
Valued Contributor
surface from splines
7 Views, 2 Replies
09-02-2009 03:14 PM
i want to reconstruct a surface I built in rhino - i have brought in splines but I'm not sure how to build it. In other programs I might loft or build from 4 edges - which I have. I am not sure what the most direct method is in max. My surface has 4 edges...the loft command doesn't exactly work the way I expect it would....any advice?
Please use plain text.
Distinguished Contributor
Re: surface from splines
09-02-2009 03:17 PM in reply to: gabriel_friedman
try the crosssection modifier or change the splines to nurbs and loft from there. you should have posted the rhino image
Distinguished Mentor
samab
09-03-2009 01:26 AM in reply to: tyree_10
or just the Surface mod may do it.
