3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
surface from splines
2 REPLIES 2
195 Views, 2 Replies
i want to reconstruct a surface I built in rhino - i have brought in splines but I'm not sure how to build it. In other programs I might loft or build from 4 edges - which I have. I am not sure what the most direct method is in max. My surface has 4 edges...the loft command doesn't exactly work the way I expect it would....any advice?
2 REPLIES 2
try the crosssection modifier or change the splines to nurbs and loft from there. you should have posted the rhino image
samab
or just the Surface mod may do it.
