3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
rotate camera view to match environment map
1 REPLY 1
tanmachine
480 Views, 1 Reply
Hi all,
I have several objects on my scene and a camera. I am about to render a image from camera view. Since I am using environment map and I want to make sure that the environment map's reference frame is the camera, I believe the best solution is to rotate the whole scene based on the camera. Is there a easy way to do so?
Thanks a lot!
1 REPLY 1
Stefan_L
in reply to: tanmachine
Why don't you rotate the environment map?
Use the "Offset" values in the coordinates rollout of the bitmap map, the "Angle" values won't work.
An U offset of 1.0 equals 360° rotation around the Z axis, but be careful with the V offset, you may get a circle of earth in the sky 🙂
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
