Show only
Search instead for
There is a way to make line spline with select edge of a mesh object. And the other would be to use a snap tool to draw a line by snapping on the consecutive vertices.
Convert an edge, or edges to a shape. 3D snapping would be faster, both have their uses. Of course a vertex selection can be converted to edges, but you may need to shrink or manually adjust the selection in that case.
