Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Modeling
Distinguished Contributor
mhr72
having a boolean problem
13 Views, 1 Replies
09-11-2009 01:25 PM
I have been having this problem in maya...wait I know this is a 3dMax forum. Let me descibe what is going on before you move this to the maya forum. So I have made this model in maya...in doing so I have used latices and other deformers split polygon tool, etc. Now after such modification maya boolean wont work...the model just disappears.
My question is. If I import this model into MAX will I be able to successfully apply a Boolean difference fuction...it may be called a subtract suction in MAX.
Does anyone have any suggestions?
Thank you
Please use plain text.
Moderator
ekahennequet
Re: having a boolean problem
09-11-2009 02:56 PM in reply to: mhr72
Thank you
It depends on your model and the version of Max you are using. Max's Boolean object allows you to subtract, add, and intersect, etc. In the past, Max's Boolean didn't like holes or overlapping vertices and created problems during Boolean ops. More recent versions of Max has ProBoolean and may work better than the older Boolean object which is still included.
ekah
