Area :: Header
New Smoke 2013 Trial!
Want to try Smoke 2013 Ext 1? We’ve updated the trial so you can check out new Blackmagic Design® hardware support and improved Trim tools.
Modeling
Lakuenza
Smoothing trouble
8 Views, 0 Replies
03-21-2012 04:27 PM
Hi everyone. What I want to do is export a smoothed high poly mesh into zbrush and then reconstruct subdivisions in zbrush. I have hard edges and vertices marked, so when I use the plus key to subdivide it works how I want it to (like smoothing groups would). However, when I export after subdividing with the plus key zbrush doesn't notice the smoothing or the subdivisions. Since marking hard edges doesn't work anywhere but Softimage, how do I get the same result as subdividing with the plus key when exporting?
Please use plain text.
