I clicked on one of those faces but it seems to count as one face as it selects the whole row also the tutor's inside/outside faces are not black like mine are is this related? How do I fix this I want to select the faces I want to select - http://i.imgur.com/dQLcwxH.jpg
even if your normals are not flipped, according to the black backfaces it´s the same solution like here: http://forums.autodesk.com/t5/Modeling/Dublicating-Instances-Problems/m-p/5026008#M8627
for the face selection problem: hard to tell from the screenshot. with just a single click it should just select a single face and from your HUD it looks like it does. so i guess there is something wrong (doubled faces) in your model. can you upload the file?
huh I just tried re creating it all in maya 2014 instead of 2015 and it doesn't have the same faces issue maybe I found a glitch or something
hey,
to be honest no there is no glitch. i dont know how but at one point you duplicated the faces or did an extrude with no thickness by accident. so by checking for nonmanifold geometry and seperating it i found a second hallway.
but glad you managed it in the mean time. repetition is good training:)
Oh thanks but how do I fix this exactly I'm a supernoob and I'm starting to just learning Maya. Also I extruded the hallways from the edges around those two door frames and I meant for it to be a single plane is that bad or something?
hard to tell without watching you doing it. in general it´s ok working that way (extruding edges, faces etc.) but mistakes can happen - thats how we learn;)
what i did to seperate it was to select the object and do a "mesh - cleanup" with the following options.
this will highlight and split some verts. switch back to object mode and do a "mesh - seperate". now sort the different parts and move away or delete the ones you don´t need. select the remaining parts and glue them back together with a "mesh - combine" and after that an "edit mesh - merge components" with a low threshold.
