Hi, I'm modeling a high-poly boombox and I have a problem with connecting vertices.
I just want to connect the vertices to the side for the right speaker as I did for the left one. For some reason, I can't do that or it only works for some of the vertices. Any idea why? I don't understand since it all worked pretty well for the left speaker.
hard to say by just looking at the picture, but I would suggest looking for having several vertices in a place where you expect (or see) only one. Sometimes they are very close or completely on top of each other and have to be welded. Other thing to look for are the polygon normals whether they are facing in the right direction. This can be seen quite well in polygon mode: They are selected in a bright red when the normal is facing at you and a darker red for the other way. Problems arise when neighbour polygons face in different directions.
