Area :: Header
Vote Now for the Flame Award!
The best artists doing the best work. Check out this year's nominees...
Discussion Groups
Modeling
Adrian Nygård
NURBS problem in spaceship project, need quick help.
16 Views, 4 Replies
03-03-2008 04:01 PM
I'm new to NURBS and I got this problem with depth on a flat or "very thin" NURBS surface, if I had the original lofting curve I could scale it down and then loft it with the corresponding isoparm but I deleted i so what could I do to fix this?
Please use plain text.
Valued Contributor
fianna
Re: NURBS problem in spaceship project, need quick help.
03-03-2008 04:43 PM in reply to: Adrian Nygård
Hey Adrian, yeah it would help to see the curve..maybe it needs a few more points. but in the meantime, you can try grabbing one of the surfaces and (Ctrl+a) in the Attribute Editor, check under Tessellation > hit Display Render Tessellation. You will see how the surface is being rendered in the hardware viewport. If you collapse Simple Tessellation Options, change the Curvature Tolerance to "Highest Quality" and increase the U+V divisions factor to 5. It should be more refined. Feel free to further tweak the settings till you're happy with the results.
BUT** once you're done (with all the other surfaces as well), remember to uncheck "Display Render Tessellation" unless you want your computer to be unhappy(ily slow). When you have the Display Render Tess turned off, you'll go back to the normal hardware view...but rest assured those settings that you modified are still there and it'll still render smooth surfaces.
hope that helps.
Adrian Nygård
03-03-2008 04:46 PM in reply to: Adrian Nygård
OMG thanks a lot, I just inserted isoparms to fix it but that method you mentioned is much easier and faster, btw now I got this new problem as you can see I updated the topic.
Valued Contributor
fianna
03-03-2008 05:21 PM in reply to: Adrian Nygård
yeah the isoparm thing might not have been the best solution. with the render tessellation, you're not so much physically altering the surface as you've just done. rather you're just telling maya this is how i want it to look when i render.
anyway, if you want to make it more 'closed' on that screenshot up there, you could just grab the isoparm closest to the edge (or trim edge, depending on how that surface has been edited) and go to Edit Curves > Duplicate Surface Curves.
Duplicate the curve and center pivot (Modify > Center Pivot) and scale it inwards a bit and then grab both curves and loft them. OR you could use that same curve (before duplicating) and v-snap a circle curve to one of the edit points and extrude. then you get a fake 'soldering' effect type look. i dont know the technical term for describing that but benefit of that is that you can scale out the circle curve to better cover/fit the gap.
Adrian Nygård
03-04-2008 02:25 PM in reply to: Adrian Nygård
Thanks a lot for the help, "Duplicate Surface Curves" lol soo obvoius! Can't believe I didn't figure that out by myself :smileytongue:
