Hey folks,
I can't get my poly-surface to turn out smooth, using the meshsmooth modifier
I'm using classic method cause I want to keep the vertex-points fixed to the other terrain-objects to avoid any air-holes being created
I'm not to familiar with the Meshsmooth modifier but I tried to change the relax and smooth parameters, no luck there.
Also tried a "smooth" parameter on top of the meshsmooth modifier with a different "smooth-angle" from 45 to 60 to 90 to 120, no luck either
