Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Merge 2 borders into one?
4 REPLIES 4
564 Views, 4 Replies
How can i megre this?
Merge Edge tool result
4 REPLIES 4
Anifex09
I am not sure what exactly you are trying to do.  But if you are trying to close the gap up you would select ether edge boarder and extrude it over to the other edge boarder to close the gap.  You then could select the verts that lie on top of one another or close to each other and merge them together.  It is also good practice to make sure you keep good edge flow.
in reply to: Anifex09
No. I am trying to combine two borders _ _ into one __
_sebastian_f
assuming you want to keep the window it just doesn´t make any sense to combine those 2 edges. there is no way in combining them without destroying the window!
and also regarding your other thread: yes keeping your geometry as clean and as low as possible but also as high as necessary is a good idea!
in reply to: _sebastian_f
there is two edges from up to down right?
just select their vertices, in the middle there should be two vertices and merge them.. it will be just one edge...
Edit: I meant here...
