How can I pull a vertex and have the others follow it like a wave. I have selected it, and i forgot how to enable it on my other pieces.
Solved by damaggio. Go to Solution.
enable "soft select". That's in the "Move" options, where you can control the extent and the direction of the falloff - or you can use the "b" hotkey.
Now it looks like this. I want it to go back to how it was before. The soft selection makes it points still. And sorry for my ignorance, but I'm new to Maya. I searched everywhere and couldnt find how to get it back to how I had it, mostly cause I don't know what I'm searching for.
In your first picture it looks like you hit the 3 key which gives you subdivision and makes it look softer when you pull a few verts...on the other picture you are still in poly mode key 1 and is sharper when you move those verts...you could change the fall off of the soft selection tool or maybe hit the 3 key to see how it looks ....however on your last picture it looks like you applied a smooth on the mesh which is not the ideal...there's a lot more polygons now.....""avoid that" ...you can hit the 3 key for that and keep the mesh as low poly as possible...thats the best way of working.
