Area :: Header
3ds Max 2015 Extension 1 is here
With new tools to power your pipeline
Discussion Groups
Modeling
Member
flyingtardis
Maya 2013 won't let me select anything but the entire model
896 Views, 9 Replies
07-16-2013 11:23 AM
hello i have been having problems with maya where i can't select  individual faces vertices or anythign other than the entire model
help on this would be greatly appreciated and as this is posted i am re-installing the programme
Please use plain text.
EarthHobbit
Re: Maya 2013 won't let me select anythin gbut the entire model
07-16-2013 01:00 PM in reply to: flyingtardis
Quick (and stupid) question. Did you right click on the object and select Vertices or Faces ?
Member
flyingtardis
07-16-2013 01:53 PM in reply to: EarthHobbit
yeah  i have tried that thats how i found out about the problem i'm having
i have read of several ways to fix it but none have worked
Product Support
tony.su
07-16-2013 07:24 PM in reply to: flyingtardis
1.select an object
2.press down right mouse button
3.move mouse to "face" option, and release mouse button
by the way, if you reinstall maya, don't forget delete or rename the user setting folder.
XP:  C:\Documents and Settings\"user name"\My Documents\maya\"version"
windows7:  C:\Users\"user name"\Documents\maya\"version"
Tony Su
Member
flyingtardis
07-16-2013 07:47 PM in reply to: tony.su
i do know how to go into face selection mode its just it will not selec whilst in face mode or edge mode or even vertex mode btu it will in object mode
EarthHobbit
07-17-2013 11:16 AM in reply to: flyingtardis
And will it work better with a new scene or another polygon ?
Member
flyingtardis
07-17-2013 11:32 AM in reply to: EarthHobbit
ive drawn new polygons imported an object file  you name it it won't work
decided to use 2011 and it seems to work better as with camera selection only it works just fine but i reckon its soemthign to do with windows vista tbh as on my laptop which is 7 it works just fine
also i'll attacth what ive been able to do in 2011
EarthHobbit
07-17-2013 12:04 PM in reply to: flyingtardis
Maybe you could try deleting the preferences files into \Users\<username>\Documents\maya\2013\en_US\prefs, and possibly contents of subdirs. I recommend to copy them elsewhere before deleting.
Product Support
tony.su
07-17-2013 07:49 PM in reply to: EarthHobbit
Delete or rename the user setting folder.
Tony Su
New Member
000004217
Re: Maya 2013 won't let me select anything but the entire model
05-23-2014 10:24 AM in reply to: flyingtardis
In the SELECT tab at the top of the screen, you will see the options OBJECT/COMPONENT for F8, VERTEX for F9, EDGE for F10, FACES for F11. It might not bet hebest way but it helps if the COMPARE TOOL or SELECT ALL come up when you hold the right mouse button.
