Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Maya 2013 won't let me select anything but the entire model
10 REPLIES 10
Message 1 of 11
flyingtardis
4109 Views, 10 Replies
hello i have been having problems with maya where i can't select  individual faces vertices or anythign other than the entire model
help on this would be greatly appreciated and as this is posted i am re-installing the programme
10 REPLIES 10
Message 2 of 11
EarthHobbit
in reply to: flyingtardis
Quick (and stupid) question. Did you right click on the object and select Vertices or Faces ?
Message 3 of 11
flyingtardis
in reply to: EarthHobbit
yeah  i have tried that thats how i found out about the problem i'm having
i have read of several ways to fix it but none have worked
Message 4 of 11
tony.su
1.select an object
2.press down right mouse button
3.move mouse to "face" option, and release mouse button
by the way, if you reinstall maya, don't forget delete or rename the user setting folder.
XP:  C:\Documents and Settings\"user name"\My Documents\maya\"version"
windows7:  C:\Users\"user name"\Documents\maya\"version"
Tony Su
Product Support
Message 5 of 11
flyingtardis
in reply to: tony.su
i do know how to go into face selection mode its just it will not selec whilst in face mode or edge mode or even vertex mode btu it will in object mode
Message 6 of 11
EarthHobbit
And will it work better with a new scene or another polygon ?
Message 7 of 11
flyingtardis
ive drawn new polygons imported an object file  you name it it won't work
decided to use 2011 and it seems to work better as with camera selection only it works just fine but i reckon its soemthign to do with windows vista tbh as on my laptop which is 7 it works just fine
also i'll attacth what ive been able to do in 2011
Message 8 of 11
EarthHobbit
Maybe you could try deleting the preferences files into \Users\<username>\Documents\maya\2013\en_US\prefs, and possibly contents of subdirs. I recommend to copy them elsewhere before deleting.
Message 9 of 11
tony.su
Delete or rename the user setting folder.
Tony Su
Product Support
Message 10 of 11
000004217
In the SELECT tab at the top of the screen, you will see the options OBJECT/COMPONENT for F8, VERTEX for F9, EDGE for F10, FACES for F11. It might not bet hebest way but it helps if the COMPARE TOOL or SELECT ALL come up when you hold the right mouse button.
Message 11 of 11
disable soft selection in your selection settings on the left hand side of your screen
