3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How to see through walls.. ie backface cull??
1 REPLY 1
ifusionnz
7883 Views, 1 Reply
Hi there,
Im trying to use the backface cull method so I can see through my exterior walls so I can design an interior inside a box but it doesnt seem to be working for me... Do I have to flip or invert the ploygons?? Heres a pic of what I have done:
1 REPLY 1
Steve_Curley
in reply to: ifusionnz
I think you're misunderstanding what Backface Cull does (and why). Convert that Box to Editable Poly and delete the Poly on the top. Turn Backface Cull on and off to see what it's doing.
To see through the sides then yes, you would have to flip all the polys so they are facing inwards. If you intend to render from inside the box (only) then you need to do that anyway otherwise it may not render correctly. Alternatively you could try X-Ray (see-thru) mode - select the Box and press Alt+X. Switch the viewport to Shaded (as opposed to Realistic) otherwise the see-thru looks very grainy.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
