Hi, Maya community!
My problem is...
I want to get a perfectly round shape like this(look at speaker)
But all I can to get is this terrible shape!
Can someone explain me, why Maya cant to even connect two half-circles properly?
Solved by Anifex09. Go to Solution.
This object created from two half-nurbs-circles (with sweep 180 degrees). Then i clicked "attach curves" (here i got this "bug" with form) and then clicked "Open/Close Curve".
P. S. I got something terrible when I tried to rebuild this curve 😞
So for the next time that you create this shape try this.
Create one Nurb Circle with the sweep angle set to 180 - duplicate the half circle and rotate it 180 degrees - Space the half circles apart - Goto Create EP Curve Option (set curve degree to 1 Linear) - make two lines connecting the two half circles (use the snap to curve constraint when creating the lines) - now select your two half circles and your two Ep Lines - goto the Edit Curves - Attach Curves Options - Set Attach method to Connect - Set Multiple knots to Remove - click attach
