Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
How do you hide selected poly faces?
9 REPLIES 9
Message 1 of 10
19093 Views, 9 Replies
I'm used to being able to select and hide polygons while creating models in programs like Lightwave and Modo. It is an essential function that I can't imagine Maya lacks, yet there isn't an obvious way to do this as far as I can tell. Is there a workaround?
9 REPLIES 9
Message 2 of 10
lee.dunham
AFAIK there's no out-of-the-box way to do this in maya.
A possible solution is a script to assign a new material (with no transparency) to the selected polys (stacking the previous material in a list or var to re-assign when your one).
there probably is a better way, however im not aware of it at the moment
Message 3 of 10
s_ehrenhaus
Hello there..
I just wrote a little script for you to be able to hide selected faces with a shelf button:
In this shelf you will find it, place that into your shelves folder.
http://dl.dropbox.com/u/25584030/shelf_PointlessScripts.mel
PS: This is a very very simple script, you need to create a shader with visibility set to 0. Ther script will look for the shading group called: lambert2SG - so make sure to name your invisible shading group like that.
You then just need to select tha faces you want to hide, and click on the shelf button.
Be Happy 🙂
Message 4 of 10
Thanks for the script. I will give it a try.
Message 5 of 10
Hello there..
I tested your script on maya 2010 it gives error saying // Error: line 31: Invalid flag: -enableBackground, and when tried to run on maya 2013 it does nothing and no error...
is it sane to write a python code and put it inside mel function, why cant you tell someone that you have made a python script and just give your python script..if u cant do it in mel...
Message 6 of 10
Not too sure if this is what you want to do.
In your viewport, 4th icon from the right, it has a green dotted line with an mouse pointer in it. It is call Isolate Select.
Message 7 of 10
brennan.mitchell
You sir, are a lifesaver. Thank you!
Message 8 of 10
a_mousavinegad
you can select faces and press h
but when you want to see all faces it is problem
in this case
you must right click and selecrt one face
then right click on face and select  "select all "
then press h
all faces  will be  show
Message 9 of 10
a_mousavinegad
in this case
then press h
Message 10 of 10
wzwow
how can i hide selected poly face from rendering?
