I know we are supposed to use UserVoice, which I'm posting too shortly... this is to add images (you can't do in UserVoice) and perhaps drive votes to UserVoice.
I'd like to see some functions that would aid some of the things I work on regularly. The scenario these two are used are often in tandem, so I'm describing them both in a single thread here.
Cap Mapping is almost always Useless
In almost all instances where I've used the Cap function (either as a modifier or in the Border mode of Editable Poly) the results invariably require effort to fix.
Here is an example of an object that was split and the interior open borders were capped.
That is never the expected result!
Here is something far more appropriate:
Although the program cannot know automaitcally which edge to use for a UV-flow, it should be able to use the first edge in the border to create a flow. It should also be able to detect a planar surface and use planar mapping coordinates. Vote for this functionality on UserVoice.
Slice Functions need some more functions
I'd like there to be a couple enhancements to Slice.
1) Add a new option like the Split option in Epoly properties called Cap* that is specifically for slice (*so named appropriately to not be confusing with the current Cap in epoly). This would consolidate the actions of cutting up an object and having to cap open borders. It should force the split to immediately apply a cap to the open borders. Request this on Uservoice.
This solves the problem of trying to cut an object into elements while trying to keep the object composed of convex sub-elements. Currently, you need to take several steps for each slice because, if you do not immediatly go cap, and then make a nother slice that crosses the plane of a previous slice, you will create a border that is not planar--and when capped is often not the desired results. It also makes the planar mapping suggestion mentioned above even more relevant because you should be able to make cuts that retain some form of mapping consistency and flow.
2) Slice Modifier Slice Plane should be updated to have a Quick Slice mode to more quickly draw the plane of a slice. The current slice plane is not convenient for scenarios when you want to slice from one specific point to another (as you can do in QuickSlice). As the Slice Modifier is convenient for using on multiple objects, I would like QuickSlice rolled into the standard slice plane UI (so the user can decide to define the plane with the slice plane gizmo, or draw the transformation of the slice plane). Vote for this on UserVoice.
Thank you for your input. Hopefully you included the link to this post in your post on User Voice. Have a good day.
Since Uservoice is gone and because the above links no longer work, here are updated links to this discussion in Ideas:
