Hi
After 7 years I'm facing the same problem as yours and found the conversation however changing the value to a positive number doesn't work. Am I missing something or it just doesn't work on Max 2015?
Hi Ivan! 🙂
I just use the Split tool in Edit Poly or Editable Poly instead of Explode in EMesh. Select all edges (or just the ones you want to break) and choose Split. Works well for me. 🙂
