Hello! Recently I've begun attaching NURBS surfaces in a new project of mine. I've been following the instructions in the book, and it had been working fine. But today I tried attaching other surfaces that were similar, using the same methods, and I get this message:
Error: attachSurface1 (Attach Surface Node): failed to compute the result.
Error: attachSurface2 (Attach Surface Node): failed to compute the result.
Error: attachSurface3 (Attach Surface Node): failed to compute the result.
Error: attachSurface4 (Attach Surface Node): failed to compute the result.
And so on.
Then it doesn't do anything. If I tell it not to keep the originals when attaching, the whole thing disappears. If I tell it to keep the originals, it appears unchanged. This is when only trying to attach two NURBS objects, not tons of them, and it had been working before. I'd been experimenting with several methods and each had been working, now none of them do. If I reload the scene it doesn't fix it. If I restart Maya it doesn't fix it. Is this an issue to do with Vista?
Please do NOT delete my question this time. It hasn't been answered!
