Hey guys,
im modelling a audi r8. It is my first car that i am modelling.
I modelled the door and i needed to the the bridge function.
In the red boxes you see the polygons i done with the bridge function.
In the Top view i cant see polygons, that i done with the bridge function.
How can i fix it ?
Thanks for your help.
What tdHendrix said might be right^^.
Go to Outliner -> select your Top Camera.
In your Attribute Editor, try changing the Translate Y to a higher number. Mine is set to 100 (you can set yours higher if you still can't see it). You might not be able to change the values by middle mouse dragging, so just enter the values manually.
