Good Afternoon Everyone,
I'm rather new to modeling and Maya in general, I'm using Maya 2014 and following along with some tutorials I've found.
Below is a cylinder that I'm working with, what I'd like to do is detach the bottom half of this cylinder, so that I only have an arch basically.
The tutorial that I'm following along with uses a NURBS object for this cylinder, however, I'd like to do this with a polygon cylinder. How can I detach what I have selected below with a polygon - much like what you would do by detaching isoparms in NURBS? End result would be cutting this cylinder into two.
Any help on this would be greatly appreciated.
Thank you! I actually found that selecting the faces and just hitting the delete key worked for me for what I was needing to do, however, I did get the extract method to work with faces. Detaching Compenents with Edge seemed to give me a bit of trouble though.
