Area :: Header
Interested in making Indie games?
Register for a Meet the Experts webinar with Digital-Tutors today!
Discussion Groups
Modeling
Valued Contributor
TheAbaeconBit
Changing color of selected objects
62 Views, 5 Replies
04-30-2008 03:03 PM
I am trying to work on a plane for work and I am having trouble now because I can't work on smooth+highlights anymore. I need to be able to see the background image but the back ground image is white. I need to change the color that the object changes to when it is selected. If anyone could help me out it would be greatly appreciated.
Please use plain text.
Distinguished Contributor
camedeck
Re: Changing color of selected objects
04-30-2008 03:25 PM in reply to: TheAbaeconBit
Go to the Customize drop down at the top of the screen and select Customize User Interface. This will open a dialog box, and you want the Colors tab. In the Elements drop-down menu, find Geometry. In the list below that, near the bottom you will find Selection. Change the color swatch to the right from white to whatever will work best for you. :smileyhappy:
Dell T7610 workstation
Dual Intel Xeon E5-2680 v2 @2.8GHz (10 core)
32 GB RAM
nVidia Quadro K5000
Window 7 Enterprise
3ds Max Design 2014
V-Ray 2.4.01
Valued Contributor
TheAbaeconBit
04-30-2008 03:26 PM in reply to: TheAbaeconBit
thanks a lot :smileyhappy:
Valued Contributor
TheAbaeconBit
04-30-2008 03:36 PM in reply to: TheAbaeconBit
hmm. I've tried it and I hit apply colors and everything and nothing seems to have changed.
camedeck
04-30-2008 03:38 PM in reply to: TheAbaeconBit
Yeah, I just did a couple tests. Seems like only a few objects took the change. Maybe try setting the new color, then restart Max and see if that helps.
32 GB RAM
nVidia Quadro K5000
Window 7 Enterprise
3ds Max Design 2014
V-Ray 2.4.01
camedeck
04-30-2008 03:43 PM in reply to: TheAbaeconBit
Okay, restarting Max worked for me. Now all my selections are Magenta! :smileyhappy: Alright, time to change back....
32 GB RAM
nVidia Quadro K5000
Window 7 Enterprise
3ds Max Design 2014
V-Ray 2.4.01
