Hey guys,
I made a very short video of what I'm doing. Basically, I want to make a cylinder with a hole through the middle.
When I:
1) Select each side of the cylinder
2) Inset
3) Delete
4) Select each edge rings
5) Bridge
I get a twisted inside of my cylinder. If I bridge 1 by 1, it works fine. . . I looked up online and they said something about "flipping" and "normals" and all that jazz. I have no idea.
I've made a little video for you of what I'm doing, so you can see the end result. How do I fix this?
Video: http://screencast.com/t/lDGB78lwfqP
What would have worked is if you didn't delete the large polys in the centre of each side of your cylinder. If you recapped those large polys on each side (for the sake of the exercise, because now that they are gone, Steve's advice about the borders is quicker now), then selected those large polys on each side (at the same time), then clicked bridge, it will bridge the polys and all of those edges will be bridged automatically, with the centre large polys deleted leaving a hole. You selected the large polys before and clicked delete. Next time select the large polys on both sides and click bridge, it'll save the step of needing to select the edge borders and clicking bridge.
If you want to bridge two closed borders don't select them beforehands, click the bridge button and choose two reference edges. Video: http://www.screencast.com/t/WO5DYqMLXn6X
Another option is clicking the Options button next to the Bridge button and changing Twist spinner values.
But as already mentioned, bridging the polygons would be preferable here. There are similar advanced options available, too.
