Hi I have a plugin that I use for Modelling Ciruits and Cars for a game called rFacotr2
To be able to import from the game to 3D Max and then Back again it needs 3DMax2010_32bit_plugins_pack unfortunalty this is only good for Max 2010. What I would like to know Is How would I go about updating 3DMax2010_32bit_plugins_pack to work with Max 2014
I am very new to these forums and I am hunting for my answer but I do not really know if it a plugin or MaxScript or if they are 1 and the same thing, any information that could be shared would be amazing.
I have added the plugin just in case it is eaier to update than to teach me how it is done this may be a quick thing if you are a person that understand this or it might be a case of totally starting again a rewriting the plugin.
Many Thanks for your ongoing support in this request
----------------------------------------------------------------------- ------------------GMT2.26(rFactor) Importer v0.94 by Zoltán Nagy------- ---------------------- Modified by Peter Holt 15/12/05 --------------------------Copy me to scripts\startup------------------- ---------------Feel free to improve this script in any way you can----- ----------------------------------------------------------------------- utility ImportGMT2 "GMT2 Importer" width:161 height:303 ( GroupBox grp1 "About" pos:[3,4] width:156 height:35 label lbl1 "GMT2 Importer v0.94 by ZN" pos:[13,20] width:138 height:17 button btnImportFile "Import a single file" pos:[15,229] width:124 height:26 GroupBox grp2 "Options" pos:[2,50] width:158 height:162 button btnImportDir "Import a directory" pos:[15,267] width:124 height:23 label lbl2 "Additional texture path:" pos:[16,64] width:128 height:16 edittext edt1 "" pos:[8,80] width:103 height:16 checkbox chkReload "Reload existing materials" pos:[12,104] width:135 height:19 GroupBox grp4 "Import" pos:[-1,210] width:160 height:87 button btnPath "Change" pos:[111,81] width:43 height:16 checkbox chkAskTexes "Ask for missing textures" pos:[12,126] width:142 height:13 checked:true radioButtons rdoSmoothing "Smoothing" pos:[12,145] width:111 height:62 labels:#("No smoothing", "Smooth everything", "Proper smoothing") default:3 columns:1 local gShaderNames local globalSearchPath fn FindStringInArray inArray inString= ( local index=0 for i=1 to inArray.count do ( if ((stricmp inArray[i] inString)==0) then ( index=i exit ) ) index ) fn ReadShaderNames= ( shaderFiles=#("bumpmap.gfx","cubemap.gfx","diffuse.gfx","specular.gfx") shaderDir=((GetDir #maxroot)+"hardwareshaders\\") for i=1 to shaderFiles.count do ( file=openFile (shaderDir+shaderFiles[i]) mode:"rt" if file != undefined then ( do ( lineInFile=readLine file words=filterString lineInFile "=" if words.count>1 then ( if (words[1]=="ShaderName") then ( shaderLevel=(execute words[2][2])+1 if (findItem gShaderNames[shaderLevel] words[2])==0 then append (gShaderNames[shaderLevel]) words[2] ) ) ) while ((eof file)==false) close file ) else messageBox "Error opening .gfx files. Extract them to 3dsmax\\hardwareshaders." ) --print shaderNames[3].count ) fn ImportGMT filename= ( local d3dBlendArray=#("ZERO","ONE","SRC COLOR","INV SRC COLOR","SRC ALPHA","INV SRC ALPHA","DST ALPHA","INV DST ALPHA","DST COLOR","INV DST COLOR") local animMethodsArray=#("Cycle","One shot","Pendulum","Transient","Random","Manual") gmtPath=getFileNamePath filename file=fopen fileName "rb" if file != undefined then ( ----------------------------------------------------------------------- ------------------------Process the Materials first--------------------- ----------------------------------------------------------------------- matEditor.Open() medit.setActiveMtlSlot 12 true matIDs=#() offsetMaterials=(ReadLong file)+4 --start of the material section in the gmt fseek file (offsetMaterials) #seek_set --jump there numMaterials=ReadLong file --number of materials if ((classof meditMaterials[1])!=multiMaterial) then meditMaterials[1]=multiMaterial numsubs:1 for m = 1 to numMaterials do ( startingPos=ftell file --store the start of this material matName=ReadString file --name of the material newMatID=0 isNewMat=true numSubs=meditMaterials[1].numSubs --look for this material in the material editor for sm=1 to numSubs do ( if ((stricmp meditMaterials[1].materialList[sm].name matName)==0) then ( newMatID=sm isNewMat=false exit ) ) local mat --create new gMat if it wasn't found if (newMatID==0) then ( if ((classof meditMaterials[1].materialList[numSubs])==gMotorMaterial) then (newMatID=numSubs+1) else (newMatID=numSubs) mat=meditMaterials[1].materialList[newMatID]=gMotorMaterial() mat.name=matName meditMaterials[1].names[newMatID]=matName ) else mat=meditMaterials[1].materialList[newMatID] --keep the actual material ID for later append matIDs newMatID if (isNewMat==true or chkReload.checked==true) then medit.putMtltoMtlEditor mat 12 ----------------------------------------------------------------------- ------------------------Material Properties---------------------------- ----------------------------------------------------------------------- fseek file (startingPos+64) #seek_set matProperties=ReadLong file --see below for details ambientRed=ReadFloat file ambientGreen=ReadFloat file ambientBlue=ReadFloat file ambientAlpha=ReadFloat file diffuseRed=ReadFloat file diffuseGreen=ReadFloat file diffuseBlue=ReadFloat file diffuseAlpha=ReadFloat file specularRed=ReadFloat file specularGreen=ReadFloat file specularBlue=ReadFloat file specularAlpha=ReadFloat file emissiveRed=ReadFloat file emissiveGreen=ReadFloat file emissiveBlue=ReadFloat file emissiveAlpha=ReadFloat file sourceBlend=ReadLong file destBlend=ReadLong file specularPower=ReadFloat file local ambientM,diffuseM,emissiveM,specularM if ((bit.and matProperties 0x200000)==0) then ambientM=true else ambientM=false if ((bit.and matProperties 0x1000000)==0) then diffuseM=true else diffuseM=false if ((bit.and matProperties 0x20000000)!=0) then emissiveM=true else emissiveM=false if ((bit.and matProperties 0x4000000)!=0) then specularM=true else specularM=false local specular,noZBuffer,twoSided,postShadow if ((bit.and matProperties 0x40)!=0) then specular=true else specular=false if ((bit.and matProperties 0x100)!=0) then noZBuffer=true else noZBuffer=false if ((bit.and matProperties 0x800)!=0) then twoSided=true else twoSided=false if ((bit.and matProperties 0x10000)!=0) then postShadow=true else postShadow=false --they are just printed into the Listener for now if (isNewMat==true or chkReload.checked==true) then ( format "\nMaterial name: %\n" matName if (ambientRed!=1.0 or ambientBlue!=1.0 or ambientGreen!=1.0 or ambientM==false) then format "Ambient: % % % M: %\n" (255*ambientRed) (255*ambientGreen) (255*ambientBLue) (ambientM) if (diffuseRed!=1.0 or diffuseBlue!=1.0 or diffuseGreen!=1.0 or diffuseM==false) then format "Diffuse: % % % M: % Alpha: %\n" (255*diffuseRed) (255*diffuseGreen) (255*diffuseBLue) diffuseM (255*diffuseAlpha) if (emissiveRed!=0.0 or emissiveBlue!=0.0 or emissiveGreen!=0.0) then format "Emissive: % % % M: %\n" (255*emissiveRed) (255*emissiveGreen) (255*emissiveBLue) emissiveM if (specularRed!=0.0 or specularBlue!=0.0 or specularGreen!=0.0) then format "Specular: % % % M: % Power: %\n" (255*specularRed) (255*specularGreen) (255*specularBLue) specularM specularPower if (specular==true) then format "specular: % \n" specular if (noZBuffer==true) then format "noZbuffer: % \n" noZBuffer if (twoSided==true) then format "twoSided: % \n" twoSided if (postShadow==true) then format "postShadow: % \n" postShadow if (sourceBlend!=2 or destBlend!=1) then format "Source blend: % Dest Blend: %\n" d3dBlendArray[sourceBlend] d3dBlendArray[destBlend] ) ----------------------------------------------------------------------- ------------------------3 Shader Desecriptors-------------------------- ----------------------------------------------------------------------- startTextures =#(0,0,0) numTextures =#(0,0,0) shaderNameIndices =#(0,0,0) for s = 1 to 3 do ( startingPos=ftell file --store current position startTextures[s]=ReadLong file --index of the first texture stage for this shader numTextures[s]=ReadLong file --number of texture stages for this shader shaderName=ReadString file --name of this shader if (s==1 and shaderName=="L1SPECULARMAPT0") then shaderName="L0SPECULARMAPT0" --hard-coded fix for a bug in specular.gfx shaderNameIndices[s]=FindStringInArray gShaderNames[s] shaderName fseek file (startingPos+264) #seek_set ) fseek file 32 #seek_cur --sometimes this 32 bytes contains something numTexturesSum=ReadLong file --sum of all texturestages for s = 1 to 3 do ( --set the 2 shader comboboxes if (isNewMat==true or chkReload.checked==true) then ( mat.shaderClass=s mat.shaderSelect=shaderNameIndices[s] ) ----------------------------------------------------------------------- ------------------------Texture Stages--------------------------------- ----------------------------------------------------------------------- for t = 1 to numtextures[s] do ( startingPos=ftell file --start of this texturestage in the file textureName=ReadString file --exactly that fseek file (startingPos+64) #seek_set --strings are 64 bytes long so jump! texProp1=ReadByte file --texture stage properties texProp2=ReadByte file anisoLevel=ReadByte file --not sure, doesn't work in editor trash=ReadByte file mipLevel=ReadLong file #signed animFrames=ReadLong file animType=0 local animMethod,animRate,animSeqStr if (animFrames!=1) then --some extra stuff to read when animation source==texture maps ( animType=1 lengthSeq=ReadLong file animSeqStr=stringStream "(" --print the anim sequence into a string seek animSeqStr 1 for l = 1 to lengthSeq do ( format "%," (ReadLong file) to:animSeqStr ) seek animSeqStr (lengthSeq*2) format ")" to:animSeqStr close animSeqStr animMethod=ReadLong file animRate=ReadFloat file ) stageType=ReadLong file --?? if (stageType==7) then --this happens when animation source==animation file, ie .bik ( animType=2 fseek file 12 #seek_cur ) else ( ukn4=ReadLong file ) cubeMapBlend=ReadFloat file --blend factor between base and cube texture usually indexStage=ReadLong file --just index of tex. stage, or texture coordinate set, or both? ukn5=ReadLong file chromaBlue=ReadByte file #unsigned --transparent color chromaGreen=ReadByte file #unsigned chromaRed=ReadByte file #unsigned chromaAlpha=ReadByte file #unsigned alphaRef=ReadLong file --alpha reference value for alpha testing lodBias=ReadFloat file fseek file 64 #seek_cur --64 bytes of trash, probably for later use --now bang everything into to gmotortexture class, when texturename!=MATH if (textureName!="MATH") and (isNewMat==true or chkReload.checked==true) then ( try ( local texture case s of --three gTex arrays for the 3 shaderlevels ( 1: texture=mat.mtl_tex0[t] 2: texture=mat.mtl_tex1[t] 3: texture=mat.mtl_tex2[t] ) local myBitmap shortName=getFileNameFile textureName if animType==1 then shortName+="00" --to find animated textures like sky00.dds try myBitmap=openbitmap (gmtPath+shortName+".dds") --very nasty way to find the textures catch ( try myBitmap=openbitmap (gmtPath+shortName+".tga") catch ( try myBitmap=openbitmap (globalSearchPath+shortName+".dds") catch ( try myBitmap=openbitmap (globalSearchPath+shortName+".tga") catch ( try myBitmap=openbitmap (gmtPath+shortName+".bmp") catch ( try myBitmap=openbitmap (globalSearchPath+shortName+".bmp") catch ( if (chkAskTexes.checked==true) then myBitmap=selectBitmap caption:("Please find: "+textureName) ) ) ) ) ) ) try ( if myBitmap!= undefined then texture.pb_bmap1=myBitmap ) catch () if (findString shortName "_CUBE")!= undefined then format "Cube map: % in Mat: % ShaderLevel: % TexStage: %\n" (textureName) (matName) s t if animType!=0 then ( texture.animType=animType texture.animNameEdit=textureName if animType==1 then ( texture.animSeqEdit =(animSeqStr as string) texture.animRate=animRate texture.animFrames=animFrames texture.animMethod=animMethod format "Animation method: % in Mat: % ShaderLevel: % TexStage: %\n" (animMethodsArray[animMethod]) (matName) s t ) ) if (bit.and texProp1 0x80)!=0 then ( texture.useChroma=on texture.chromaColor=color chromaRed chromaGreen chromaBlue ) if (bit.and texProp1 0x1)!=0 then texture.noReduce=on if (bit.and texProp2 0x80)!=0 then texture.noCompress=on if (bit.and texProp2 0x1)!=0 then texture.uniqueTex=on texture.coordinates.mapChannel=t --texture coordinates channel texture.blendPct=cubeMapBlend*100 if alphaRef<0x3f then texture.chromaBlend=3 --translate alpha reference into chromaBlend else if alphaRef<0x7f then texture.chromaBlend=2 else if alphaRef<0xbf then texture.chromaBlend=1 else texture.chromaBlend=0 texture.mipBias=lodBias texture.mipType=1 if mipLevel==-1 then texture.MIPLevel=0 else texture.MIPLevel=mipLevel texture.filterType=bit.and texProp1 48 texture.anisoLevel=anisoLevel try ( if (bit.and texProp1 0x2)!=0 then texture.renderTarget=on ) catch( format "" ) --checking render target causes an exception if (s==1 and t==1) then showTextureMap mat texture on --show the first dx7 texture ) catch ( format "Exception: % Mat: % ShaderLevel: % TexStage: %\n" (getcurrentexception()) (matName) s t ) ) ) ) ) try ( medit.setActiveMtlSlot 1 true ----------------------------------------------------------------------- ------------------Get the world matrix and the pivot point------------- ----------------------------------------------------------------------- local isTransformed=false local matTransform,vecPivot fseek file (0xf4+4) #seek_set m11=ReadFloat file if m11!=0 then ( m12=ReadFloat file m13=ReadFloat file m14=ReadFloat file m21=ReadFloat file m22=ReadFloat file m23=ReadFloat file m24=ReadFloat file m31=ReadFloat file m32=ReadFloat file m33=ReadFloat file m34=ReadFloat file m41=ReadFloat file m43=ReadFloat file m42=ReadFloat file --flip y and z m44=ReadFloat file matTransform=matrix3 [m11,m12,m13] [m21,m22,m23] [m31,m32,m33] [m41,m42,m43] ReadFloat file pX=ReadFloat file pZ=ReadFloat file pY=ReadFloat file vecPivot=point3 pX pY pZ isTransformed=true ) ----------------------------------------------------------------------- -------------------------------Get our mesh---------------------------- ----------------------------------------------------------------------- fseek file (0x170+4) #seek_set numTrilists=ReadLong file --number of triangle lists/strips startTrilistDesc=ReadLong file --start of trilist headers vertArray =#() normalArray =#() colorArray =#() uv1Array =#() uv2Array =#() uv3Array =#() uv4Array =#() faceArray =#() faceArrayOpt =#() matIDArray=#() startIndex=1; for m = 0 to (numTrilists-1) do ( ----------------------------------------------------------------------- ------------------------Trilist or Tristrip Descriptor----------------- ----------------------------------------------------------------------- fseek file (startTrilistDesc+4+m*132) #seek_set nUkn0 = ReadLong file --strip or list, see below startPosNormal = ReadLong file trash=ReadLong file startTexCoords = ReadLong file trash=ReadLong file startTanBinormal=ReadLong file --tangents and binormals only when there's bumpmapping numVertices = ReadLong file trash=ReadLong file numIndices = ReadLong file startIndices = ReadLong file fseek file (16) #seek_cur indexMaterial = ((ReadLong file)+1) --material ID ----------------------------------------------------------------------- ------------------------Vertex Position, Normal, Color----------------- ----------------------------------------------------------------------- fseek file (startPosNormal+4) #seek_set for v = 1 to numVertices do ( x=ReadFloat file z=ReadFloat file --flip y and z for max y=ReadFloat file pos=point3 x y z append vertArray pos nx=ReadFloat file --normal, not used here nz=ReadFloat file ny=ReadFloat file append normalArray (normalize [nx,ny,nz]) blue=ReadByte file #unsigned --vertex color, not sure in order green=ReadByte file #unsigned red=ReadByte file #unsigned alpha=ReadByte file #unsigned append colorArray [red/255.0,green/255.0,blue/255.0] trash=ReadLong file --something ) ----------------------------------------------------------------------- -------------------------UV data(4 channels per vertex)---------------- ----------------------------------------------------------------------- fseek file (startTexCoords +4) #seek_set for v = 1 to numVertices do ( u=ReadFloat file v=ReadFloat file append uv1Array [u,-v,0] u=ReadFloat file v=ReadFloat file append uv2Array [u,-v,0] u=ReadFloat file v=ReadFloat file append uv3Array [u,-v,0] u=ReadFloat file v=ReadFloat file append uv4Array [u,-v,0] ) ----------------------------------------------------------------------- -------------------------Indices--------------------------------------- ----------------------------------------------------------------------- fseek file (startIndices+4) #seek_set if (bit.and nUkn0 0x20000000)!=0 then --we have a trilist ( for f = 1 to (numIndices/3) do ( i1=((ReadShort file)+startIndex) i2=((ReadShort file)+startIndex) i3=((ReadShort file)+startIndex) append faceArray [i1,i2,i3] append faceArrayOpt [i1,i2,i3] append matIDArray matIDs[indexMaterial] ) ) else --it's a tristrip ( if numIndices>=3 then ( i1=((ReadShort file)+startIndex) i2=((ReadShort file)+startIndex) for i = 3 to (numIndices) do ( i3=((ReadShort file)+startIndex) if (i1!=i2 and i1!=i3 and i2!=i3) then --ignore degenerate crap ( if (mod i 2)>0.00001 then ( append faceArray [i1,i2,i3] append faceArrayOpt [i1,i2,i3] ) else ( append faceArray [i3,i2,i1] append faceArrayOpt [i3,i2,i1] ) append matIDArray matIDs[indexMaterial] ) i1=i2 i2=i3 ) ) ) startIndex+=numVertices --the triangle lists/strips are put into a single mesh ) print rdoSmoothing.state if (rdoSmoothing.state==3) then ( try ( for v = 1 to (vertArray.count-1) do ( vertV=vertArray[v] local vj=v+1 for vjfor = (v+1) to (vertArray.count) do ( if vertV==vertArray[vj] and (dot normalArray[v] normalArray[vj])>0.98 then ( for f = 1 to (faceArrayOpt.count) do ( if faceArrayOpt[f].x>vj then faceArrayOpt[f].x-=1 else if faceArrayOpt[f].x==vj then faceArrayOpt[f].x=v if faceArrayOpt[f].y>vj then faceArrayOpt[f].y-=1 else if faceArrayOpt[f].y==vj then faceArrayOpt[f].y=v if faceArrayOpt[f].z>vj then faceArrayOpt[f].z-=1 else if faceArrayOpt[f].z==vj then faceArrayOpt[f].z=v ) deleteItem vertArray vj deleteItem normalArray vj ) else vj+=1 ) if v>=(vertArray.count-1) then exit ) ) catch ( format "Exception during fancy smoothing: %\n" (getcurrentexception()) ) ) --create our mesh, setup texture coordinates newMesh=mesh vertices:vertArray faces:faceArrayOpt materialIDs:matIDArray newMesh.material=meditMaterials[1] fseek file (0x190+4) #seek_set newMesh.name=ReadString file meshop.setNumMaps newMesh 5 keep:true meshop.setMapSupport newMesh 4 true meshop.setNumMapVerts newMesh 0 uv1Array.count meshop.setNumMapVerts newMesh 1 uv1Array.count meshop.setNumMapVerts newMesh 2 uv1Array.count meshop.setNumMapVerts newMesh 3 uv1Array.count meshop.setNumMapVerts newMesh 4 uv1Array.count meshop.setNumMapFaces newMesh 0 newMesh.numFaces meshop.setNumMapFaces newMesh 1 newMesh.numFaces meshop.setNumMapFaces newMesh 2 newMesh.numFaces meshop.setNumMapFaces newMesh 3 newMesh.numFaces meshop.setNumMapFaces newMesh 4 newMesh.numFaces vertList=#() for v = 1 to (uv1Array.count) do ( meshop.setMapVert newMesh 0 v colorArray[v] meshop.setMapVert newMesh 1 v uv1Array[v] meshop.setMapVert newMesh 2 v uv2Array[v] meshop.setMapVert newMesh 3 v uv3Array[v] meshop.setMapVert newMesh 4 v uv4Array[v] append vertList v --setNormal newMesh v normalArray[v] ) for f = 1 to (newMesh.numFaces) do ( meshop.setMapFace newMesh 0 f faceArray[f] meshop.setMapFace newMesh 1 f faceArray[f] meshop.setMapFace newMesh 2 f faceArray[f] meshop.setMapFace newMesh 3 f faceArray[f] meshop.setMapFace newMesh 4 f faceArray[f] setFaceSmoothGroup newMesh f 1 ) if (isTransformed) then ( newMesh.transform=matTransform newMesh.pivot=vecPivot ) if (rdoSmoothing.state==2) then meshop.weldVertsByThreshold newMesh vertList 0.000001 --update newMesh --said to update normals etc., not actually needed imo ) catch ( format "Exception during Geometry importing: %\n" (getcurrentexception()) ) fclose f ) ) on ImportGMT2 open do ( dx7Shaders=#() dx8Shaders=#() dx9Shaders=#() gShaderNames=#(dx7Shaders,dx8Shaders,dx9Shaders) ReadShaderNames() globalSearchPath="d:\\rFactor\\rFToolsPublic\\SampleTrackPiece\\maps\\" ) on btnImportFile pressed do ( globalSearchPath=edt1.text fileName = getOpenFileName types: "GMT(*.gmt)|*.gmt|All|*.*|" if filename != undefined then ( ImportGMT filename ) ) on btnImportDir pressed do ( globalSearchPath=edt1.text directory = getSavePath caption:"Import Directory" initialDir: edt1.text if directory != undefined then ( files=GetFiles (directory+"\\*.gmt") for filename in files do ImportGMT filename ) ) on btnPath pressed do ( directory = getSavePath caption:"Additional Texture Path" initialDir: edt1.text if directory != undefined then ( edt1.text=directory+"\\" ) ) )
