I've tried a few times to install Mockup 360 without success. I tried on (2) PCs and got bluescreened. Then I installed a Microsoft hotfix and followed these instructions from Autodesk. I did not get a blue screen but received a message that stated that the software could not be run.
I'm running Windows 7 / 64bit
I am sorry to hear you are having issues installing Mockup 360.
When you received a message that stated that the software could not be run, did there happen to be an installation log or any kind of additional information about the problem?
Also when you say you received a message, was this during the installation or after the install was successful and you attempted to launch or log into Mockup 360?
Blue screen here as well.
Mac Pro, Windows 7
have you tried installing Mockup360 again?
We have made changes to prevent the Blue Screen issue and would like to know if it now works for you.
Lucia Casu
Mockup360 Support
I tried on my laptop and received this message:
"Cannot Start Application"
"Application cannot be started. Contact the application vendor."
I clicked on the details and here is what came up:
PLATFORM VERSION INFO Windows : 6.1.7601.65536 (Win32NT) Common Language Runtime : 4.0.30319.18444 System.Deployment.dll : 4.0.30319.18408 built by: FX451RTMGREL clr.dll : 4.0.30319.18444 built by: FX451RTMGDR dfdll.dll : 4.0.30319.18408 built by: FX451RTMGREL dfshim.dll : 4.0.41209.0 (Main.041209-0000)
SOURCES Deployment url : https://mockup360-core.autodesk.com/download/64bit/Mockup360.application Server : Microsoft-IIS/7.5 X-Powered-By : ASP.NET Deployment Provider url : http://download.autodesk.com/SWDLDNET3/M360PR/Client/Mockup360.application Server : Apache Application url : http://download.autodesk.com/SWDLDNET3/M360PR/Client/Application%20Files/Mockup360_4_0_13000_1023/Mo... Server : Apache
IDENTITIES Deployment Identity : Mockup360.application, Version=4.0.13000.1023, Culture=neutral, PublicKeyToken=4f80ad5c5f19b589, processorArchitecture=amd64 Application Identity : Mockup360.exe, Version=4.0.13000.1023, Culture=neutral, PublicKeyToken=4f80ad5c5f19b589, processorArchitecture=amd64, type=win32
APPLICATION SUMMARY * Installable application. * Trust url parameter is set. ERROR SUMMARY Below is a summary of the errors, details of these errors are listed later in the log. * Activation of https://mockup360-core.autodesk.com/download/64bit/Mockup360.application resulted in exception. Following failure messages were detected: + The application binding data format is invalid. (Exception from HRESULT: 0x800736B2)
COMPONENT STORE TRANSACTION FAILURE SUMMARY No transaction error was detected.
WARNINGS There were no warnings during this operation.
OPERATION PROGRESS STATUS * [6/20/2014 9:41:15 AM] : Activation of https://mockup360-core.autodesk.com/download/64bit/Mockup360.application has started. * [6/20/2014 9:41:25 AM] : Processing of deployment manifest has successfully completed. * [6/20/2014 9:41:25 AM] : Installation of the application has started. * [6/20/2014 9:41:26 AM] : Processing of application manifest has successfully completed. * [6/20/2014 9:41:35 AM] : Found compatible runtime version 4.0.30319. * [6/20/2014 9:41:35 AM] : Request of trust and detection of platform is complete. * [6/20/2014 9:43:37 AM] : Downloading of subscription dependencies is complete. * [6/20/2014 9:43:37 AM] : Commit of the downloaded application has started.
ERROR DETAILS Following errors were detected during this operation. * [6/20/2014 9:43:37 AM] System.Runtime.InteropServices.COMException - The application binding data format is invalid. (Exception from HRESULT: 0x800736B2) - Source: System.Deployment - Stack trace: at System.Deployment.Internal.Isolation.IEnumSTORE_ASSEMBLY.Next(UInt32 celt, STORE_ASSEMBLY[] rgelt) at System.Deployment.Internal.Isolation.StoreAssemblyEnumeration.MoveNext() at System.Deployment.Application.ComponentStore.CollectCrossGroupApplications(Uri codebaseUri, DefinitionIdentity deploymentIdentity, Boolean& identityGroupFound, Boolean& locationGroupFound, String& identityGroupProductName) at System.Deployment.Application.SubscriptionStore.CommitApplication(SubscriptionState& subState, CommitApplicationParams commitParams) at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc) at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl) at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS No transaction information is available.
sorry to hear that you're still unable to install the application.
Did you try uninstalling previous versions and cleaning the cache as described in this thread?
http://forums.autodesk.com/t5/Mockup-360-General/Can-t-install-Mockup360/m-p/4950834#M114
Lucia Casu
Mockup360 Support
Thanks for the link. I uninstalled it along with process analysis 360 and cleared the cache then attempted to reinstall it but I received this error:
Mockup360 Setup
"An error occurred attempting to install Mockup360."
Below are the details:
An error occurred trying to download 'https://mockup360-core.autodesk.com/download/64bit/Mockup360.application'.
See the setup log file located at 'C:\Users\nstalker\AppData\Local\Temp\VSD6E10.tmp\install.log' for more information.
Here are the contents of the log file:
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [InstallMode] = HomeSite {string}
Property: [NTProductType] = 1 {int}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.1.1 {version}
Running checks for package 'Visual C++ 2012 Runtime Libraries (x64)', phase BuildList
Running MsiProductCheck with ProductCode '{CF2BEA3C-26EA-32F8-AA9B-331F7E34BA97}'
MsiQueryProductState returned '5'
Setting value '5 {int}' for property 'VCRedistInstalled'
The following properties have been set for package 'Visual C++ 2012 Runtime Libraries (x64)':
Property: [VCRedistInstalled] = 5 {int}
Running checks for command 'vcredist_x64\vcredist_x64.exe'
Result of running operator 'ValueGreaterThanEqualTo' on property 'VCRedistInstalled' and value '3': true
Result of checks for command 'vcredist_x64\vcredist_x64.exe' is 'Bypass'
'Visual C++ 2012 Runtime Libraries (x64)' RunCheck result: No Install Needed
Running checks for package 'Microsoft .NET Framework 4.5 (x86 and x64)', phase BuildList
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full'
Read string value '4.5.50938'
Setting value '4.5.50938 {string}' for property 'DotNet45Full_TargetVersion'
The following properties have been set for package 'Microsoft .NET Framework 4.5 (x86 and x64)':
Property: [DotNet45Full_TargetVersion] = 4.5.50938 {string}
Running checks for command 'DotNetFX45\dotNetFx45_Full_x86_x64.exe'
Result of running operator 'ValueEqualTo' on property 'InstallMode' and value 'HomeSite': true
Result of checks for command 'DotNetFX45\dotNetFx45_Full_x86_x64.exe' is 'Bypass'
Running checks for command 'DotNetFX45\dotNetFx45_Full_setup.exe'
Result of running operator 'ValueNotEqualTo' on property 'InstallMode' and value 'HomeSite': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'DotNet45Full_TargetVersion' and value '4.5.50709': true
Result of checks for command 'DotNetFX45\dotNetFx45_Full_setup.exe' is 'Bypass'
'Microsoft .NET Framework 4.5 (x86 and x64)' RunCheck result: No Install Needed
Running checks for package 'Mockup 360 Client Check', phase BuildList
Looking up path for special folder 'LocalAppDataFolder'
Running check with folder 'C:\Users\nstalker\AppData\Local\Apps\2.0' and file 'Mockup360.exe'
Unable to find directory 'C:\Users\nstalker\AppData\Local\Apps\2.0'
Not setting value for property 'MOCKUP_EXE_VER'
Reading value 'DisplayVersion' of registry key 'HKCU\Software\Microsoft\Windows\CurrentVersion\Uninstall\a6c6037ecb86e27a'
Unable to read registry value
Not setting value for property 'REG_CLIENT_VER'
Reading value 'DisplayVersion' of registry key 'HKCU\Software\Microsoft\Windows\CurrentVersion\Uninstall\5f861183f6c6ba37'
Not setting value for property 'REG_CLIENT_CERT_VER'
The following properties have been set for package 'Mockup 360 Client Check':
Running checks for command 'Mockup360 Client Check\clientversioncheck.exe'
Result of running operator 'ValueNotExists' on property 'MOCKUP_EXE_VER': true
Result of checks for command 'Mockup360 Client Check\clientversioncheck.exe' is 'Bypass'
'Mockup 360 Client Check' RunCheck result: No Install Needed
Running checks for package 'Windows Installer 4.5', phase BuildList
Looking up path for special folder 'WindowsFolder'
Running check with folder 'C:\Windows\System32' and file 'msi.dll'
Attempting to find file 'C:\Windows\System32\msi.dll'
File version is '5.0.7601.17807'
Setting value '5.0.7601.17807 {version}' for property 'VersionMsiDll'
The following properties have been set for package 'Windows Installer 4.5':
Property: [VersionMsiDll] = 5.0.7601.17807 {version}
Running checks for command 'WindowsInstaller4_5\WindowsXP-KB942288-v3-x86.exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '4.5': true
Result of checks for command 'WindowsInstaller4_5\WindowsXP-KB942288-v3-x86.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsXP-KB958655-v2-x86-ENU.exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsiDll' and value '4.5.6001.22299': true
Result of checks for command 'WindowsInstaller4_5\WindowsXP-KB958655-v2-x86-ENU.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4-x86.exe'
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4-x86.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003-KB958655-v2-x86-ENU.exe'
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003-KB958655-v2-x86-ENU.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4-x64.exe'
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4-x64.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003.WindowsXP-KB958655-v2-x64-ENU.exe'
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003.WindowsXP-KB958655-v2-x64-ENU.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MSU'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsiDll' and value '4.5.6001.22308': true
Result of checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MSU' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x64.MSU'
Result of checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x64.MSU' is 'Bypass'
'Windows Installer 4.5' RunCheck result: No Install Needed
Launching Application.
URLDownloadToCacheFile failed with HRESULT '-2146697208'
Error: An error occurred trying to download 'https://mockup360-core.autodesk.com/download/64bit/Mockup360.application'.
Did you install Mockup from the Trial page?
http://www.autodesk.com/products/mockup-360/free-trial
Which browser did you use for the install?
Lucia Casu
Mockup360 Support
I am glad it worked!
I will mark the post as "solved" if it's ok?
Lucia Casu
Mockup360 Support
