Mockup 360 Forum (Read Only)
Welcome to Autodesk’s Mockup 360 Forums. Share your knowledge, ask questions, and explore popular Mockup 360 topics.
Mockup 360 Application failed to run
5 REPLIES 5
GNR88
2922 Views, 0 Replies
Hi all,
I've having trouble getting mockup 360 to run. I double click the icon on the desktop, it says lauching aplication for a second then i get the splash screen for a moment then nothing.
I have tried installing from Firefox and Internet explorer and manually.
 Made sure my Virus scanner is off and windows fire wall, and user access control is off
I'm running Windows 8 64bit, Java is upto date 64bit version
Not sure what else to check? Or am I missing something obvious
5 REPLIES 5
joel.palioca
in reply to: GNR88
Hi GNR88,
Could you try deleting the 3 files and the Mockup360 folder in the path below and relaunch the product?
%Userprofile%\AppData\Local\Autodesk\Web Services
Please let me know if this helps at all or if you still have issues and we can follow up to see how to resolve this problem.
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
GNR88
in reply to: joel.palioca
I am now up and running
Thank you for your help!
If you need any more infomation to help stop this from happening to others let me know.
dinhhien22989
in reply to: GNR88
Why did the Mockup 360 Application fail? I have lots of works that needs to be done. Do you have any solution?
Shelley
contactJ2JUV
in reply to: GNR88
Ok nice  !
