I am finding the measure capability of Mock very limiting and frustrating mostly due to a lack of snapping.
How do I measure the distance between two holes? center to center?
How do I select center points (circular faces)? edges?
It seems that all I can do is face-to-face dimensions... is this it?
Hi Mike,
At this point Mockup supports faces and edge points for its measure command.
We are currently in the proccess of evaluating new measure commands that can be added for Mockup. Other than measure the distance between two holes, center to center, selection of center points (circular faces) and edges, do you have any additional measurements that would be useful for the work you need to do?
Thanks for your feedback,
