Mockup 360 Forum (Read Only)
Welcome to Autodesk’s Mockup 360 Forums. Share your knowledge, ask questions, and explore popular Mockup 360 topics.
Filenames can't contain -?
7 REPLIES 7
Message 1 of 8
cmcconnell
1487 Views, 0 Replies
This is a problem - every single filename we have has 2 - in it. Can this be addressed?
Mechanix Design Solutions inc.
7 REPLIES 7
Message 2 of 8
liang_chen
in reply to: cmcconnell
Are you meaning that the mockup file name can't contain '-' ?
When create a new mockup file in mockup 360, the file name only support letters, digits, underscores and space with the length of 24 charactors. Currently, it is as designed
If the status mentioned above is an issue for you, we could investigate how to support '-' in file name.
Fred
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Message 3 of 8
cmcconnell
in reply to: liang_chen
Yes this is a HUGE problem for us and my clients. We have 2 - in every single filename we have.
Message 4 of 8
liang_chen
Thanks for your feedback.
This case has been reported in our internal issue tracking system, and we are working on it.
Fred
Fred Chen
SQA Engineer
Autodesk, Inc.
Message 5 of 8
joel.palioca
Hi Cory,
Can you try this workflow again with the most recent update that has been pushed?  You should notice that "-" is now supported for filenames.
Would enjoy hearing how things go.
Cheers,
Joel
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
Message 6 of 8
cmcconnell
in reply to: joel.palioca
Just getting back to this now - tried to install and it bluescreened.
Message 7 of 8
joel.palioca
Hi Cory,
Sorry to hear that you are running into the BSOD issue.  Have you had a chance to apply the fix we have listed in the ReadMe for this issue?  If you have time below is the steps to take to fix the BSOD issue.  Shouldn't take more than a few minutes to accomplish this.  Look forward to hearing if the file name issue has been resolved for you.
- There is currently an open issue with the Microsoft “click-once” installation when run on the Windows 7 platform that may result in a blue screen during installation or updating Mockup 360. To resolve this install MS hotfix located at::http://support.microsoft.com/kb/2675806/en-us
Once you’ve installed the hot fix and restarted your computer follow the instruction below to reinstall mockup 360:
  1. Delete the Mockup 360 shortcuts located in both the desktop and ‘Autodesk’ folders under Windows Start Menu.
  2. Delete the files listed in the path below, whose names contain ‘mock’: C:\Users\<user name>\AppData\Local\Apps\2.0
  3. Reinstall Mockup 360.
[Joel Palioca]
Autodesk, Inc.
Message 8 of 8
Kareem Francis
Sr. Support Analyst
Global Customer Service & Support
Autodesk, Inc.
