This is a problem - every single filename we have has 2 - in it. Can this be addressed?
Are you meaning that the mockup file name can't contain '-' ?
When create a new mockup file in mockup 360, the file name only support letters, digits, underscores and space with the length of 24 charactors. Currently, it is as designed
If the status mentioned above is an issue for you, we could investigate how to support '-' in file name.
Fred
Yes this is a HUGE problem for us and my clients. We have 2 - in every single filename we have.
Thanks for your feedback.
This case has been reported in our internal issue tracking system, and we are working on it.
Fred
Hi Cory,
Can you try this workflow again with the most recent update that has been pushed? You should notice that "-" is now supported for filenames.
Would enjoy hearing how things go.
Cheers,
Joel
Just getting back to this now - tried to install and it bluescreened.
Hi Cory,
Sorry to hear that you are running into the BSOD issue. Have you had a chance to apply the fix we have listed in the ReadMe for this issue? If you have time below is the steps to take to fix the BSOD issue. Shouldn't take more than a few minutes to accomplish this. Look forward to hearing if the file name issue has been resolved for you.
- There is currently an open issue with the Microsoft “click-once” installation when run on the Windows 7 platform that may result in a blue screen during installation or updating Mockup 360. To resolve this install MS hotfix located at::http://support.microsoft.com/kb/2675806/en-us
Once you’ve installed the hot fix and restarted your computer follow the instruction below to reinstall mockup 360:
