Mockup 360 Forum (Read Only)
Welcome to Autodesk’s Mockup 360 Forums. Share your knowledge, ask questions, and explore popular Mockup 360 topics.
Can't install Mockup360!
8 REPLIES 8
Message 1 of 9
kent
2699 Views, 0 Replies
Impossible to install Mockup360!!
Pls see attached logfile.
8 REPLIES 8
Message 2 of 9
liang_chen
in reply to: kent
HI Kent, There is an open issue that click once installation fail if the online app cache is not clean. Can you pls try the workaround below and re-install again ? Please let us know whether it can solve your issue Solution: 1. Click Start, click Run, type “cmd”, and then click OK. 2. Type this command, and then press Enter: “rundll32 dfshim CleanOnlineAppCache” Or “delete the cached file under %userprofile%\Local Settings\Apps” Thanks Fred
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Message 3 of 9
kent
in reply to: kent
Sorry that didn?t work? still the same error?
Best regards
___________________
Kent Norling
Autodesk Inventor / AutoCAD Certified Professional
CADCAM-it AB
Storgatan 11
806 45 G?VLE
Sweden
Tel: +46 (0)26-660010
Fax: +46 (0)26-660011
Mobil: +46 (0)70-2690604
kent@cadcam-it.se
www.cadcam-it.se
www.cadcamitbloggen.com
Message 4 of 9
DanioZhu
in reply to: kent
from the log, it looks like the processanalysis360 and mockup360 cache (both install with clickonce) was corrupted, could you try to uninstall processanalysis360, remove the cache folder "C:\Users\[your account name]\AppData\Local\Apps\2.0", then install mockup360 again?”
Message 5 of 9
nstalker
in reply to: DanioZhu
Should I uninstall Autodesk Fusion 360 as well?
Message 6 of 9
DanioZhu
in reply to: nstalker
Could you attach the log which can be found from "%temp%\Mockup360Installer.txt"? so that we can check what's going wrong.
Message 7 of 9
nstalker
I don't see a "Mockup360Installer.txt" in the "%temp%" folder.
Message 8 of 9
nstalker
tried reinstalling it again today and it worked!
Message 9 of 9
luciacasu
Thanks for the update.
The install log file should be located in the folder
%userprofile%\appdata\local\temp
Lucia Casu
Mockup360 Support
Lucia Casu
Fusion360 Development
