Kev,
Most likely the server is dropping the users connection and then
re-establishing it moments later. As a result, the files become
read-only (look at the top bar). This is quite common when network
issues exist. To put it mildly, the problem is in the network
somewhere.
- drew
On Sat, 24 Feb 2001 07:38:08 -0800, "Kevin Wehner"
wrote:
>We recently upgraded our server. The operating system changed from Novell to
>Win2k Server. Now, in MDT and A2k, we ocassionally get a problem saving
>drawings. MDT will say that the file has been opened and saved by another
>user. You have to save your file as another file name. Is this a known
>issue? Is there a fix? We have had this happen six times in the past two
>days. For some reason, I suspect it will get worse.
>Also, we used to rely on Novell's salvage utility to get old backup files
>that had been overwritten. It came in really handy when a MDT file would
>become corrupt for some unknown reason. Is there a similar utility that can
>be purchased for Win2k Server?
>Kevin B Wehner
>Mechanical Engineer
>kevin.wehner@electricdevice.com
>http://www.electricdevice.com
>p: 330.702.3227
>f: 330.533.2639
>Electric Device Corporation
>464 Lisbon St
>Canfield, OH 44406
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Check out my MDT & Inventor FAQ @ http://www.mymcad.com/
