i didn;t mention it, because it seemed logical, but in case it wasn't
obvious, in the example i used 75 was the line number and if i wanted to use
the new prompt, it would ahve been 97
Brian
"Brian Carpenter" wrote in message
news:41C01CFA6D3DE7450A7194FF77B4F16A@in.WebX.maYIadrTaRb...
> Yes I was able to bet my own suctom prompt to show up. When you add a
line,
> you need to include a line number at the start of the line.
> ie 97 "Material Finish" like i used in the gentitis.mld....... make sure
> you save the MLD. file. when you adjust the properties of the attibute
> (where it says "(genmsg "gentitis" 75)". or something similar) make sure
you
> change the line reference number to the number of the line you added. It
> should display the appropriate prompt the next time you load a new title
> block. Remember, if you try to delete the title block and insert the new
> version, ACAD will tend to ignore a duplicate definition of the block, so
> after you delete, make sure that you purge out the previous version of the
> title block from the drawing. If you are using Multi Language Support for
> your drawings, ensure that the prompt is placed in the appropriate order
in
> the list ( the order it shown in the very first line of the MLD file). If
> you wish, you can even creat you own MLD file, as long as you save it
inthe
> same folder as the others and it follows the same conventions. in this
case
> your promt line would be "(genmsg "My_file" 75)". or something similar..
> experiment and have fun
> Brian
> "Chris Hutchinson" wrote in message
> news:FD3DC715576FFED228C746FB2D31ED9E@in.WebX.maYIadrTaRb...
> > I messed with the MLD file this past weekend...I'd modify a prompt to a
> > custom prompt but it wouldn't show up when I inserted my title
> > block???...Were you able to get any changes to the MLD file to show???
> > Thanks,
> > Chris Hutchinson
> > Duke Energy Corp.
> > Charlotte, NC
> > news:B752BC5E7072AFA0BF3D086C891653E4@in.WebX.maYIadrTaRb...
> > > Ian
> > > GENTITIS refers to a file, GENTITIS.MLD located in the
> > > \MDT5\ACADM\TRANSLATOR Directory ( FOLDER, sorry really old DOS wonk
> here)
> > > this is a text file and it has a listing of the various items. as in
> your
> > > example 75 refers to the line lable #75 and there you do see Drawing
> > > Activity as the prompt for the dialog box you refer to.
> > > You can add lines and modify existing lines for custom prompts here,
or
> > you
> > > can, using the PROPERTIES command, change the prompt to something
else.
> > > Remember to save your custom title block under it's own file name, and
> to
> > > add your custom title block to your AMOPTIONS title block setting.
> > > Hope that this helps
> > > Brian
> > > Ohh yeah...... the {16.1}.....I had fun getting info on that..... it
> > > describes the maximum width of the text string based on the text
hight.
> > for
> > > example, if you have 5mm text hight, and the text needs to fit into a
> > 100mm
> > > space the number would be {20.0} or 100/5. When the text string would
> > > normally excede this 100mm lenght, it will compress the text width to
> fit
> > > into the 100mm space.
> > > Brian
> > > "Ian Barrow" wrote in message
> > > news:837C096EEA5E3C2F6B7AE06294903A28@in.WebX.maYIadrTaRb...
> > > > I am trying to create a new title block based on the existing
> > > > "BSI_TITLEB.DWG" file.
> > > > When the existing file is inserted into a drawing I am shown a
dialog
> > box
> > > > for the attributes asking for the drawing number, title, drawing
> > activity
> > > > and so on. When the "BSI_TITLEB.DWG" file is opened the attribute
for
> > > > drawing activity is shown as "GEN-TITLE-DACT{16.1}" and by using
> DDEDIT
> > on
> > > > this I am shown that this is the tag and the prompt is "(genmsg
> > "gentitis"
> > > > 75)". I thought that the prompt would read "DRAWING ACTIVITY". Could
> > > someone
> > > > please tell me how to change this or create new attributes.
