Thanks for the feedback Chuck.
Would undoing the steps in the lower assembly, and then redoing them in the upper
assembly work. Or maybe I am not understand what "outside of the assembly" means. I
will have to try it if I get a chance.
Kent
"Chuck Savatsky" wrote in message
news:8FF55B2E8687EDDD426917B4B4CDA7CE@in.WebX.maYIadrTaRb...
> I verified that we do indeed have a bug relating to this. If I do a
> restructure outside
> of the assembly, I am losing graphics in the scene for the components I
> restructured.
> As of this point, I do not know a better workaround than recreating the
> scene. Externalize/localize
> does not help. I'm still looking for a better workaround. The bug is
> definitely something
> that should be fixed in SP2.
> Chuck.Savatsky@Autodesk.com
> Chuck Savatsky
> MDT developer
> Autodesk
> news:6DFEA5E6864D6CE7F6CF49EA5D0D9F27@in.WebX.maYIadrTaRb...
> > Kent/Jeff/Glenn,
> > Just so we are all clear on amrestructure:
> > When you drag components from one subassembly in the browser to another
> > location (up or down the
> > assembly tree), this is using the amrestructure command is used. This
> would
> > be the same as if you
> > had typed in the command, amrestructure.
> > I'm in the process of trying to reproduce Glenn's problem with respect to
> > doing a restructure OUTSIDE of
> > the context of the top level assembly and losing graphics in the top level
> > assembly as a result of it.
> > I'll reply to this thread if I find anything out.
> > Chuck Savatsky
> > MDT developer
> > Autodesk
> > "Jeff Howard" wrote in message
> > news:4D7F3029DA32B26A9BDF44791671C370@in.WebX.maYIadrTaRb...
> > > Glenn,
> > > I could be totally wrong, but I think someone is pulling your leg and
> you
> > > have a data base problem. I routinely drag components from one assy to
> > the
> > > next from within any level in the assembly, delete a part from one sub
> and
> > > add it to another, etc. etc. and do not loose, in the top assy, parts
> from
> > > scenes or dwg views. I've never heard of amrestructure, until you
> > mentioned
> > > it.
> > > Some things I'd look at:
> > > Have you manually forced an update of the scenes and are you sure they
> > > aren't locked?
> > > Do you put part or subassy Definitions or Instances (emphasis on both of
> > > them) on layers other than 0? You open a can of worms if you do and you
> > > need to check the layer status, etc. for all your parts and assy's.
> This
> > > can apply to the scenes also, as they have some strange ties to the
> layer
> > > that's current when they are created.
> > > I strongly suggest you set audit control to always if you haven't.
> > > Have you gone through any external parts or assy's with audit control
> on,
> > > done an amupdate all, possibly an audit, etc.?
> > > A long shot is to instance your top level assy into a new assy, localize
> > it,
> > > externalize it and see what happens. Keep backup copies of everything
> in
> > > case dwg views are lost, etc.
> > > Good luck with it,
> > > Jeff
> > > "Glenn Freeman" wrote in message
> > > news:546F70DDDCB2CE883F74E2AABEF27F53@in.WebX.maYIadrTaRb...
> > > Yes, the part is visible. I just got a call from our local reseller who
> > > called Autodesk and I was told I am SOL. I can not move a part from a
> > > subassembly of a subassembly to the subassembly and expect the part to
> > show
> > > up in an original scene of the top level assembly unless I use the
> > > amresctructure command and move the part from the subassembly of the sub
> > > assembly up to the sub assembly from inside the highest level assembly.
> > > (Say that 5 times fast)
> > > I would post the file but it is about 40 meg unzipped and in order to
> > upload
> > > it would take about 3 years.
> > > Glenn Freeman
