Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
amthread display in pspace
12 REPLIES 12
Message 1 of 13
182 Views, 12 Replies
ok here goes. draw a cube, drill a hole blind any depth just not through. drill a tapped hole (bigger in dia than the 1st) concentric to the first, drill it blind but not as deep as the first. create a drawing view and look at the thread detail, it goes all the way to the bottom of the first cylinder.............bug?? methinks it might be 🙂
12 REPLIES 12
Message 2 of 13
Hi Steve,
Looks like I am not able to reproduce the problem
you are talking about. The thread appears fine for me( threads appear only for
the second hole that i create). It would be helpful if you could post a small
file that causes this behaviour for you.
Thank You,
Raj Kumar,
Software QA Engineer,
Autodesk, Inc.
ok
Message 3 of 13
have you tried in in sp1? it was fine in previous version
Message 4 of 13
Yes. I tried this in Sp1(unless I am getting the
steps to repro wrong!)
have
Message 5 of 13
okay im posting a file that shows the prob. this file also cover my other thread 'thread' scuse the pun 🙂 the post will be called thread.
Message 6 of 13
Hmmm may be a bug, but if you uncheck full depth, and put in a value of 20 then it looks
right.
Kent
"steveoliver" wrote in message
news:f084379.-1@WebX.maYIadrTaRb...
Message 7 of 13
Hi Steve,
I am sorry but I am not able to open the .dat that
you have posted. I would appriciate it if you could post a .dwg file.
Thanks!
Raj Kumar,
Autodesk, Inc.
okay
thread.
Message 8 of 13
Raj
Just save it and then change the extension to dwg. It comes across as a dwg in my
newsreader. Not sure why the NG software does that to some files.
Kent
"Raj Kumar" wrote in message
news:57CBD181A21F63B6B1C47F09CE6829E3@in.WebX.maYIadrTaRb...
> Hi Steve,
> I am sorry but I am not able to open the .dat that you have posted. I would appriciate
it if you could post a .dwg file. Thanks!
> Raj Kumar,
> Autodesk, Inc.
news:f084379.3@WebX.maYIadrTaRb...
Message 9 of 13
Kent,
Saving and changing the extension to dwg does not help. It does not convert
it to a dwg file. I am not sure as to why this is happening.
Raj.
"Kent Keller" wrote in message
news:3E36D4D7EF9B1519E5B817C41CE8AB06@in.WebX.maYIadrTaRb...
> Raj
dwg in my
> Kent
> > Hi Steve,
would appriciate
> > Raj Kumar,
> > Autodesk, Inc.
other thread
Message 10 of 13
Hi Steve,
Since I am not able to view the file that you have
posted, I have posted a drawing file based on your steps to repro. Please let me
know if I am missing something.
Raj kumar,
Autodesk,Inc.
okay
thread.
Message 11 of 13
Just guessing.... I haven't tried changing it, but it looks like the difference might be
Steve has a flat end on the hole Anyhow I reposted his zipped up. Hopefully you can get
that one.
Kent
news:8BA917FCDD8A708E06F79B7B7A8D8FA3@in.WebX.maYIadrTaRb...
> Hi Steve,
> Since I am not able to view the file that you have posted, I have posted a drawing file
based on your steps to repro. Please let me know if I am missing something.
> Thanks,
> Raj kumar,
> Autodesk,Inc.
Message 12 of 13
Thanks Kent and yes the flat end is the trouble maker. I have logged a
defect against this.
Raj.
news:030DFB954A8A7AC5EA10D98F81A7BAB5@in.WebX.maYIadrTaRb...
difference might be
> that one.
> Kent
> > Hi Steve,
a drawing file
something.
> > Thanks,
> > Raj kumar,
> > Autodesk,Inc.
other thread
Message 13 of 13
thanks guys and thanks kent for the possible workaround, i really didnt think of messing with the depth! still learning all the time eh? 🙂
