Just noticed it while in paperspace. Regening didn't clear it up. But,
flipping between Model space and paperspace did.
Dick Upton wrote in message
news:5CFD979ED305753BB8B78D96206DDB27@in.WebX.maYIadrTaRb...
> Walter,
> I have seen the same behavior where no setting of viewres or facetres will
> "smooth" out the model. The only thing that seems to help is to save the
> file, exit, and come back in. I've not seen it enough times to figure out
if
> there might be some way to fix it, and it doesn't happen all the time.
It's
> a little irritating, but I'm not sure its not just me doing something
wrong.
> I can't post a file either because the minute I go out of the offending
file
> and come back in it's fixed, and I can't seem to recreate the steps it
took
> to get that way.
> Dick
> Walter Zabawa wrote in message
> news:119286184B597BF5F8080D12FCBDA0EC@in.WebX.maYIadrTaRb...
> > Jeff,
> > I'm not talking about 2d, this is 3D part (not a solid) but "surface"
> model.
> > When I'm zoomed out, everything looks pretty smooth, but if I zoom in
> tight
> > on say a SURFACE fillet, it looks "jagged" (like the viewres is set
low),
> > but
> > once I do a regen when zoomed in, everything looks good.
> > The REGENAUTO is on, I did try changing the facetres to 8 or so (did not
> > help)
> > I did just today install the service pak 1, no help, same thing. I can
> only
> > assume
> > this is a bug, and once again AutoCAD has taken 1 step forward and 2
steps
> > back.
> > As I have found other problems with MDT6 that I did not have with MDT5.
> > Any guesses would be nice.
> > Walter
> > "Jeff Howard" wrote in message
> > news:A239FA72B6BA819A3A4C871BAD72DE9D@in.WebX.maYIadrTaRb...
> > > Walter,
> > > Since a regen smooths everything up, I'm assuming you are talking
about
> 2d
> > > wireframe mode and don't think there have been any changes to this
sort
> of
> > > stuff with mdt6. I routinely run with facetres set to 8 and viewres
set
> > to
> > > 20000.
> > > One off the wall suggestion is to check the variable REGENAUTO and
make
> > sure
> > > it's on.
> > > Jeff
> > > "Walter Zabawa" wrote in message
> > > news:176B2C22577562EBFEA35434A468AABE@in.WebX.maYIadrTaRb...
> > > I have my "viewres" set to 15000, when zoomed out arcs/circles look
> great,
> > > nice and smooth. But when I zoom in
> > > close, all arcs/circles (surfaces) get jagged and I must "regen" to
get
> > > smooth lines again. Why is this, is it a bug
> > > or something I've missed, don't recall having this problem in MDT5?
> > Someone
> > > please help me.
> > > Walter Zabawa
> > > (wzabawa@msn.com) ....Failure is not an option, it comes bundled with
> the
> > > software & service!!
> > > (walter-zabawa@webtv.net) ....was most reliable, until the MSN
takeover
