So you mean that changing the overall scale of your dimstyle would directly update all your dimensions?
When placing new dimensions the OVERALL DIM SCALE setting (on the FIT-tab in DIMSTYLE) is being ignored and it just used the value 1. (Just to make clear, I am talking about the size of the dim text and arrows)
It does accept other changes, like color, arrow style, textheight etc. But it just ignores the overall scale setting...
After I typ in the command line : DIM, UP, ALL it does update though
From then it seems to follow all changes in DIMSTYLE settings box.
I am using my own personalised style. Which has been set in AM:STANDARDS under DIMENSION: SETTINGS
When doing a multi edit (AMDIMMEDIT) to change the "precision" on multiple dims, only the first selected dim updates. Additional text does get added to all of them...
It very well could be a specific setting but where to find it? I have already tried a lot of the settings in AM:options under AM;standards.
I am using the latest version of MDT (2009)
Thanks for any tips
