Mechanical Desktop
New Member
andjo024
Message 1 of 2 (175 Views)
Using parameters in assembly
175 Views, 1 Replies
08-02-2011 02:10 AM
I wonder if there is a way to create some kind of global variable that affects the parameters in parts in an assembly?
Employee
Sridhar-Autodesk
Message 2 of 2 (169 Views)
Re: Using parameters in assembly
08-04-2011 08:05 PM in reply to: andjo024
You may use AMVARS command to create Global Variables in MDT 2009.  Please find attached sample drawing with a sub assembly of 2 parts.
Command: amvars>>Switch to Global Tab>>Change the value of "Driveme" variable.  The whole assembly updates.
Hope this helps.
Sridhar Subramani
Autodesk, Inc.
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
