IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Using parameters in assembly
1 REPLY 1
390 Views, 1 Reply
I wonder if there is a way to create some kind of global variable that affects the parameters in parts in an assembly?
1 REPLY 1
Sridhar-Autodesk
You may use AMVARS command to create Global Variables in MDT 2009.  Please find attached sample drawing with a sub assembly of 2 parts.
Command: amvars>>Switch to Global Tab>>Change the value of "Driveme" variable.  The whole assembly updates.
Hope this helps.
Sridhar Subramani
Senior Product Owner
