Mechanical Desktop
Member
tforal
Message 1 of 4 (1,727 Views)
Accepted Solution
Unable to install content libraries for Autocad Mech 2010 64-bit on Windows 7
1727 Views, 3 Replies
05-18-2011 11:39 AM
Having an issue installing the concent libraries for Autocad Mechanical on a 64-bit Windows 7 machine.  During the install it give me this error (Error 1320. The specified path is too long: c:\documents and settings\all users).  If I go into configure the installation to modify the Content libraries under Autocad Mechanical 2010, it gives me this error (C:\Documents and Settings\All Users\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb).  Any ideas?
Tammy
Employee
rogermollon
Message 2 of 4 (1,721 Views)
Re: Unable to install content libraries for Autocad Mech 2010 64-bit on Windows
05-18-2011 05:02 PM in reply to: tforal
Tammy,
Since this Mechanical Desktop (MDT) Forum is not for AutoCAD Mechanical, I suggest that you post in the AutoCAD Mechanical Forum:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
or possibly better the Installation and Licensing Forum where the install experts hang out:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I hope this helps,
Roger Mollon
Sr. Director, Software Development
Design, Lifecycle, & Simulation Product Group
Autodesk, Inc.
Employee
Sridhar-Autodesk
Message 3 of 4 (1,719 Views)
05-18-2011 07:45 PM in reply to: tforal
Hi, Tammy
The default install location for content libraries on a Vista or Windows 7 OS machine is as follows
C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb
Can you try the above path during installation and verify if it works?
Please find attached snapshot.
Sridhar Subramani
Autodesk, Inc.
New Member
markofVis
Message 4 of 4 (1,171 Views)
02-07-2013 06:37 AM in reply to: Sridhar-Autodesk
This problem is no longer a considered because it has been solved.There is away to fix this problem and the name of that software is Long Path Tool.I highly recommend it to you since I have already used it.
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
