Hmmm not sure, I think it is available in VBA, would have to double check, and the other
way to go about it is to use amsymscale / amrescale. That of course affects other things
also though.
Yup, it is supported in VBA
This changes it to a value of 2
Option Explicit
Public Sub txtsize()
Dim mcad As McadApplication
Set mcad = ThisDrawing.Application.GetInterfaceObject("Mcad.Application")
Dim symbb As McadSymbolBBMgr
Set symbb = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
symbb.StandardMgr.CurrentStandard.TextHeight = 2
End Sub
Kent
"Dick Upton" wrote in message
news:0AD5B9751D0A75EBE088BFB834FF243D@in.WebX.maYIadrTaRb...
> By the way when I click on that and adjust the value, do you know what
> variable I'm adjusting?
> Kent Keller wrote in message
> news:64FF5EE43952E1D99BFBC0AEA43E44F9@in.WebX.maYIadrTaRb...
> > Dick
> > What you should do is really pretty much up to your tastes Personally
> I keep things
> > simple (just like me) and use the same size for all drawings.
> > How do you bring in the titleblock? It might be pretty easy to have a
> macro or lisp that
> > sets the value when you insert the titleblock.
> > Kent
> > news:C680447140350666AA31F57B4068AAE2@in.WebX.maYIadrTaRb...
> > > Thanks for the replies all. That worked. What if I need 0.12 for b size
> > > drawings and 0.188 for d size drawings? Should I:
> > > 1. Create a different but parallel standard for each drawing size?
> > > 2. Manually flip back and forth as needed?
> > > 3. Forget about making differing text heights that are drawing size
> > > dependent?
> > > 4. Create Dimstyles and use dimstyles (yuck, never used them before)?
> Will
> > > amnote honor these?
> > > Thanks again and best regards and hoping all yours is safe and sound,
> > > Dick
> > > Tom Costan wrote in message
> > > news:2E6D07F01A7F3483DAAD0133A70EE256@in.WebX.maYIadrTaRb...
> > > > amoptions and RMB on your standard. Color and size is controlled by
> this
> > > > dialog. (pretty sure about this 🙂
> > > > -Tom
> > > > news:1F7E3BA8D4595AEE12F095829603D0C6@in.WebX.maYIadrTaRb...
> > > > > Does anyone know how to change the text size of an AMNOTE? I've
> tried
> > > > > changing DIMTXT and TEXTSIZE to 0.188, but the AMNOTE insists on
> coming
> > > in
> > > > > at 0.120. I can't seem to find anything in AMOPTIONS > Standards.
> Hope
> > > > > nobody minds the snap.
> > > > > TIA, Dick
