IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Text size of amnote
16 REPLIES 16
Message 1 of 17
254 Views, 16 Replies
Text size of amnote
Does anyone know how to change the text size of an AMNOTE? I've tried
changing DIMTXT and TEXTSIZE to 0.188, but the AMNOTE insists on coming in
at 0.120. I can't seem to find anything in AMOPTIONS > Standards. Hope
nobody minds the snap.
TIA, Dick
16 REPLIES 16
Message 2 of 17
Dick
Can't double check right now, but I think that is controlled by amoptions and then
double click on the top item on the list (I think it is the standard name)
Kent Keller
http://kwik-mcad.scriptmania.com/
Check out the Mechanical Desktop FAQ @
http://mymcad.com/
See the MDT/ Inventor wishlists!
www.cadsense.co.nz/wishmain.htm
"Dick Upton" wrote in message
news:1F7E3BA8D4595AEE12F095829603D0C6@in.WebX.maYIadrTaRb...
> TIA, Dick
Message 3 of 17
Assist\format\dimension style
click on the text tab and change the text size.
If that is not the problem you might want to try and edit the text style
(assist\format\text styles) and edit the default text size there.
Glenn Freeman
> TIA, Dick
Message 4 of 17
amoptions and RMB on your standard. Color and size is controlled by this
dialog. (pretty sure about this 🙂
-Tom
> TIA, Dick
Message 5 of 17
Thanks for the replies all. That worked. What if I need 0.12 for b size
drawings and 0.188 for d size drawings? Should I:
1. Create a different but parallel standard for each drawing size?
2. Manually flip back and forth as needed?
3. Forget about making differing text heights that are drawing size
dependent?
4. Create Dimstyles and use dimstyles (yuck, never used them before)? Will
amnote honor these?
Thanks again and best regards and hoping all yours is safe and sound,
Dick
Tom Costan wrote in message
news:2E6D07F01A7F3483DAAD0133A70EE256@in.WebX.maYIadrTaRb...
> -Tom
in
> > TIA, Dick
Message 6 of 17
Dick
What you should do is really pretty much up to your tastes Personally I keep things
simple (just like me) and use the same size for all drawings.
How do you bring in the titleblock? It might be pretty easy to have a macro or lisp that
sets the value when you insert the titleblock.
Kent
news:C680447140350666AA31F57B4068AAE2@in.WebX.maYIadrTaRb...
> dependent?
> amnote honor these?
> Dick
> > -Tom
> in
> > > TIA, Dick
Message 7 of 17
That's exactly what I used to do in R14. I'll fiddle with that. Thanks. See
that's the beauty of MDT - you can leverage your previous experience for
what it may be worth.
Dick
Kent Keller wrote in message
news:64FF5EE43952E1D99BFBC0AEA43E44F9@in.WebX.maYIadrTaRb...
> Dick
I keep things
macro or lisp that
> Kent
> > dependent?
Will
> > amnote honor these?
> > Dick
this
> > > -Tom
tried
coming
> > in
Hope
> > > > TIA, Dick
Message 8 of 17
By the way when I click on that and adjust the value, do you know what
variable I'm adjusting?
> Dick
I keep things
macro or lisp that
> Kent
> > dependent?
Will
> > amnote honor these?
> > Dick
this
> > > -Tom
tried
coming
> > in
Hope
> > > > TIA, Dick
Message 9 of 17
Hmmm not sure, I think it is available in VBA, would have to double check, and the other
way to go about it is to use amsymscale / amrescale. That of course affects other things
also though.
Yup, it is supported in VBA
This changes it to a value of 2
Option Explicit
Public Sub txtsize()
Dim mcad As McadApplication
Set mcad = ThisDrawing.Application.GetInterfaceObject("Mcad.Application")
Dim symbb As McadSymbolBBMgr
Set symbb = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
symbb.StandardMgr.CurrentStandard.TextHeight = 2
End Sub
Kent
news:0AD5B9751D0A75EBE088BFB834FF243D@in.WebX.maYIadrTaRb...
> > Dick
> I keep things
> macro or lisp that
> > Kent
> > > dependent?
> Will
> > > amnote honor these?
> > > Dick
> this
> > > > -Tom
> tried
> coming
> > > in
> Hope
> > > > > TIA, Dick
Message 10 of 17
Oh scary. Now I get to delve into the world of acad vba. Is it any harder
than lisp or do I just have a mental block? I knew this day would come
sooner or later. So there's no way to do it in lisp?
news:1733D4A105D37A2DAFB4B4CB75BDF49E@in.WebX.maYIadrTaRb...
and the other
> also though.
> Option Explicit
> Set mcad =
> Set symbb =
> End Sub
> Kent
> > > Dick
Personally
> > I keep things
> > macro or lisp that
> > > Kent
size
> > > > dependent?
before)?
> > Will
> > > > amnote honor these?
sound,
> > > > Dick
by
> > this
> > > > > -Tom
> > tried
> > coming
> > > > in
Standards.
> > Hope
> > > > > > TIA, Dick
Message 11 of 17
Dick
What are the names and locations of the titleblocks you would be inserting? Are you a
command line, or a toolbutton guy? Do you like dialog boxes or just a toolbutton or
command line call?
Kent
news:7A6ACF8E072485DE816259B858CD3791@in.WebX.maYIadrTaRb...
Message 12 of 17
I'm a command line guy - fer sher.
c:\support\blk\h?-size.dwg, where "?" is the sheet size A-E and R (for
roll - double long E)
news:C3300D6E2BE2A0BA7A35D2AD47D54356@in.WebX.maYIadrTaRb...
> Dick
toolbutton or
> command line call?
> Kent
harder
Message 13 of 17
Dick
See customer files for a VBA project
If you add some lines like this to your acaddoc.lsp (add similar ones for all your sizes,
just change the asize in both places to bsize etc....)
(defun c:asize()(command "-vbarun" "Titleblock.dvb!aSize"))
and you save the VBA project somewhere in the Autocad path it should work
If you need help give a holler.
Kent
news:F1FB77DD77C9649C39C338AC9F60E893@in.WebX.maYIadrTaRb...
> > Dick
> toolbutton or
> > command line call?
> > Kent
> harder
Message 14 of 17
Opps stirring to many pots at once here, just realized I think that file still had my
drawing referenced in the cSize section. You need to open it in the vbaide and where it
says
sSize = "j:\dwg\dwglib\2d\coutlin.dwg"
'sSize = "c:\support\blk\hc-size.dwg"
delete the first sSize line, and then remove the ' from the second.
Kent
Message 15 of 17
Very nice. I have a book here by Joe Sutphin called "AutoCAD 2000 VBA
Programmer's Reference", and have been meanin' to get a Round TUIT, so this
may just be the kick in the pants I've been needing. Did you do that from
scratch, or did you already have something lieing about?
When I first ran it it gave me an error, but then I noticed there was a "-"
missing off the file name that I gave you. So I typed in VBAIDE and found
the line and changed it. Voila.
Just curious what variable controls the arrowhead size. What extra line of
code would I need to control that as well?
news:810EDADCD0D1FABF73F7F09C96DA5950@in.WebX.maYIadrTaRb...
file still had my
vbaide and where it
> says
> Kent
Message 16 of 17
Nevermind, I poke around for awhile (just like in lisp) and got it. Now I'm
going to figure out how to let the user (that's me) place the titleblock.
Wish me luck.
Dick Upton wrote in message
news:88DE2555F0BC33AAA5BD7703DDE03250@in.WebX.maYIadrTaRb...
this
> file still had my
> vbaide and where it
> > says
> > Kent
Message 17 of 17
No it was from scratch with the exception of I stole a small section of the insert
block code from help. The Vanilla VBA help is very good, and programs can easily be
written by taking a little snip of this code and a little snip of that code and
mixing it all together. There is really very little code in that, it is just the
same thing over 5 times with one or two small changes to each section.
Good luck on the mods.
Kent Keller
http://mymcad.com/
> Very nice. >
