Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Sweeps don't support table driven variables
14 REPLIES 14
Message 1 of 15
212 Views, 14 Replies
I have an assembly of a small pumping station. The parts - pump, motor, drivebase, shed etc. - are all local and are constrained using values and global design variables. I have two table driven variants ie. the pump is in a different location for each variant. In MS I can activate either variant and the pump locates correctly. However the associated piping - generated using 3D pipe path and sweep and global design variables - will not change. The pipe path accepts design variables but immediately converts them to values which are used for the piping in both variants. Editing the Excel spreadsheet has no effect and the design variables dialogue box shows that the design variables for the pipe path are Unused.
Also, is there a way of hiding a part file in one variant while unhiding it in another?
And while I'm on the subject why does a scene generated from the first variant change to be the same as the scene generated by the second variant?
Or have I missed something!
14 REPLIES 14
Message 2 of 15
Can't help with the spread sheet issue, but is scene locking what you need
for the different configurations?
Would it be feasible for you to make each configuration a different assembly
file (saveas, change components, etc)? This might cure all the problems,
assuming they were linked to different spread sheets. (2 cents worth)
Jeff
RobertB wrote in message
news:f082f4a.-1@WebX.maYIadrTaRb...
in another?
Message 3 of 15
I haven't tried it, but I wonder if you made the part then made a new empty part, .... did
a amcombine to join the original part if you could then suppress the combine with the
table? ... the part would still be there but it would be empty...... (if it worked)
Kent
"RobertB" wrote in message news:f082f4a.-1@WebX.maYIadrTaRb...
Message 4 of 15
Jeff, Thanks for your reply. I made two assembly files, scrapped the spreadsheet and moved on. Pity though.
RobertB
Message 5 of 15
Kent, See my reply to Jeff. Can I add 'design variable' support for sweeps to a wish list. Robert
Message 6 of 15
Can you make a small example of what you were trying to do? I am probably not
understanding, but for a quick test, I just made 3 global variables, then I made a
3dpoly, and ran am3dpath Pipe option on it. I plugged the global variables in a
couple of spots for the path, and then I changed the variables values and the path
updated.
Obviously this isn't tied to Excel, and I haven't actually swept the part but am I
missing something else?
For wishlists, go to the link below. Brian has put up a great list, and I think the
developers are actually using it for planning future additions.
Kent Keller
http://kwik-mcad.scriptmania.com/
Check out the Mechanical Desktop FAQ @
http://mymcad.com/
See the MDT/ Inventor wishlists!
www.cadsense.co.nz/wishmain.htm
"RobertB" wrote in message news:f082f4a.3@WebX.maYIadrTaRb...
wish list. Robert
Message 7 of 15
I made a sample .dwg and .xls but can't post it to the CF. I get a message saying that no sender name is given and I don't know what to do about it. But you are on the right track. Now create a spread sheet, make a second variant, give the variables new values and update the link. In your dwg, selecting the variants in turn should alter the pipe path but it doesn't. The design variable dialogue box reflects the table driven values but display a U as well as a T indicating that they are unused.
Robert
Message 8 of 15
Can you just reply to me with it, and I will post it to customer files for you? If
I get a chance I will play with the info below, but it is always quicker to take
something someone else has done so we are both on the same page for things.
Kent Keller
http://mymcad.com/
"RobertB" wrote in message news:f082f4a.5@WebX.maYIadrTaRb...
are unused.
> Robert
Message 9 of 15
I'm feeling stupid. I tried copy and paste but it won't work. Robert
Message 10 of 15
Kent, I appreciate your help. You've got a living to make too. I succeeded in posting 'ampipe sample.dwg' and 'ampipe sample.xls' to the CF. Robert
Message 11 of 15
Robert
Me??? Make a living??? Just imagine how crazy I would be if I actually made a
income
Well I see what you mean, when the variable is used in the Length field. But it
works in the other fields?? I reposted your drawing and excel . It looks like I
should have left the first row alone or something because it jumps around when you
change styles, but it is a way to approach it anyhow. Good luck.
Kent Keller
http://mymcad.com/
"RobertB" wrote in message news:f082f4a.9@WebX.maYIadrTaRb...
Message 12 of 15
Ignore my first post to customer files. I had two copies of the dwg, and sent the
one I didn't do anything to. Duhhh
Kent Keller
http://mymcad.com/
Message 13 of 15
Robert,
For some reason I couldn't download your sample dwg, even though the spreadsheet would.
I had quick play with table driving a 3d pipe & it appears to work if you apply the variables to the Delta X, Y & Z boxes all the others seem to accept the text but then revert back to the dimn as you say marking the variable field with a U. You would think if it accepts info in some of the boxes it would in all of them, maybe this is actually a bug ? It would be pretty handy if you could RMB & get the typical drop down for accessing the equation assistance etc.
Cheers, Graham
Message 14 of 15
So..... is it logged as a bug?? Please forgive my naivity, but what does RMB mean? Robert
Message 15 of 15
RMB= Right Mouse Button
Kent Keller
http://mymcad.com/
"RobertB" wrote in message news:f082f4a.13@WebX.maYIadrTaRb...
Robert
