IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
PowerDimension and Dimscale - Help!
3 REPLIES 3
150 Views, 3 Replies
Why does power dimensioning override my dimstyle by changing the dimscale to
1.00? And how do I fix it?
3 REPLIES 3
Michael,
Are you running SP1? Pre - SP1 the dimscale for power dims is controlled by
the variable AMSYMSCALE.
Jeff
"Michael Benoy" wrote in message
news:D5279EC2DE6B621161A8473296734C2A@in.WebX.maYIadrTaRb...
It's doing this on MDT5 and MDT6 SP1, but I haven't tried changing
AMSYMSCALE.
"Jeff Howard" wrote in message
news:11FB9961D095EF473E369C7B74C739C9@in.WebX.maYIadrTaRb...
> Michael,
by
> Jeff
to
That's not the problem, then, as 5 didn't have the variable and 6/sp1
behaves differently.
Sorry, I've got a finite element model cooking and can't open mdt to check
this out, but you might check amoptions > standards > dimension and see if
"Force usage of predefined dimension style" is checked. This may be causing
mdt to use a dim style other than what you intend to use. Also, somewhere
among all the dimension dialogs ("model scale" on the standards tab?) there
is a setting that will effect dimscale, but I don't remember the
particulars.
Jeff
news:4C126046889310E998782D2BB87B330A@in.WebX.maYIadrTaRb...
AMSYMSCALE.
